Friction factor inside a pipe with low very low Reynolds number locally |
August 22, 2022, 07:36 |
anuj
Rep Power: 6 |
I am solving a single phase Turbulent flow problem inside a pipe. Inside the domain there is some obstruction ( solid bodies) where the velocity ( locally) is very very low and therefore Reynolds number comes out to be very low[order of 10^(-6)]. I have written a custom fields function inside Ansys Fluent which calculates friction factor. The correlation for friction factor has been taken from literature where friction factor is inversely proportional to Reynolds number.
When my plot contours of friction factor, it's maximum value comes out in the range of 1500~2000 at places where Reynolds number is very low. How can I solve this? Is it possible to have friction factor greater than 1? Also if I consider Moody's chart , the lowest Reynolds number mentioned in the chart is 60. Please help |
August 22, 2022, 12:13 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
What kind of turbulence would you supppose at such a low Re number… |
August 22, 2022, 13:54 |
Lucky
Rep Power: 65 |
I have to say there is a lot here that is inconsistent with the general approach of pipe flows.
I'm not sure what you mean by local Reynolds number. For pipes we use the bulk averaged Reynolds numbers. Obstructions cause local acceleration, not deceleration. There is no meaning to a friction factor value anywhere close to or greater than 1, that would mean the flow loses more than its entire bulk share of dynamic head and pressure becomes negative. Friction factor is also a single scalar, there is no local contour of friction factor. A lot of clarifications are needed. Can we please just start over from the very beginning? |
Display Modes | |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 10:23 |
Seakeeping Solver:Crashed | akbarbagusd | Fidelity CFD | 0 | November 5, 2021 13:42 |
High reynolds number model and a low reynolds number model | Ieg1995 | Main CFD Forum | 3 | June 18, 2017 14:18 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 15:53 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
