Multiblock. Interface BC
Old   November 19, 1998, 13:05
Default Multiblock. Interface BC
Kyros Yakinthos
Hello to everyone. Here is a question. Suppose that you have a multiblock grid topology. You solve the N-S equations in a non-staggered CV and you must find a condition concerning let's say the velocity at the grid connectivity interface between 2 connecting blocks (or for the mass at the face..). The momentum interpolation method is adopted to avoid the pressure wingles.You have a point-to-point matching interface.
What is the best way for the boundary condition there ? I've tryed a straightforward interpolation but the result was bad.
Any suggestion ? Thank you in advance
Old   November 20, 1998, 08:39
Default Re: Multiblock. Interface BC
Franck Bertagnolio
Concerning your boundary conditions at interface between 2 connected blocks, instead of a simple interpolation, I guess that an interface boundary condition preserving the fluxes would give much better results.
Technically speaking, it should not be too difficult in your case since the interface is conformal (point-to-point matching interface). Then, you should be able to compute the fluxes (of mass, momentum...) at the faces of one block and enforcing the latter at the faces of the neighbouring block.
Good luck.
Old   November 23, 1998, 18:58
Hansong Tang
Your question sounds interesting. But, could you says some details about your problem? For instance, what's your numerical schemes in subzones? Is the flow compressible or incompressible?
We have done some research about schemes for grid interfaces. Maybe we can exchange ideas.
Hansong Tang
Thread Tools
Trackbacks are On
Wind turbine simulation Saturn CFX 45 February 8, 2016 05:42
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
Multiblock grid, interface Boundary condition Nandu CFX 2 August 6, 2002 05:07
