numerical error
Old   March 30, 2001, 11:24
Default numerical error
bal
is it possible to compensate for error of coarse mesh (large cell size) by having higher order terms for discretizing the N-S equations
Old   March 31, 2001, 02:26
Default Re: numerical error
John C. Chien
(1). If you retain more higher order terms, then these higher order terms will need more mesh points to approximate them. (2). That means, in the same area, you will have to refine the mesh. This will become more difficult near a boundary.
Old   April 1, 2001, 09:09
Sebastien Perron
Usually, Higher Order interpolation functions will give you more precision. But in order to construct these functions, you'll need more points. As an exemple, with finite elements or FVEM, If you compute two solutions with the same number of degrees of freedom (unknowns), one with P1 functions and the other with P2 functions, the one with P1 functions sould be more dependant on the mesh (more error prone). But, These results only hold if the stability conditions for both scheme are satisfied.
Old   April 3, 2001, 09:39
Peter Young
For a given mesh, it's not easy to judge if the HOD schemes give better results - take centeral difference as example, the Tayler expansion indicates that it's second order accurate which really means that if you refine your mesh, the numerical error will go down much faster than the first order scheme. If your mesh is reasonably fine, then HOD schemes normally give more accurate results.
Old   April 5, 2001, 14:09
alexy
Solution matrix bandwidth of higher order methods can be contained and kept the same as that of lower order methods. Please check out a paper by A.Kolesnikov and A.J.Baker "Efficient implementation ... " available at http://cfdlab.engr.utk.edu/html/publ...ns/public.html in postscript. The theory has been extended to NS fomulations (look in dissertations section on the same web page).
Old   April 5, 2001, 14:26
John C. Chien
(1). Thank you. (2). I think you are probably talking about the finite element method, by just looking at the authors names.
Old   April 5, 2001, 14:50
alexy
The analysis is performed on an assembled fe stencil, which makes it applicable to fd formulations.
Old   April 5, 2001, 15:22
kalyan
A question related to this issue.
If you want higher order discretization but low matrix band width, do you need to solve more equations (more dependent variables) than in the method with higher order discretization and higher band width. If this is the case, you have to choose between solving a matrix with high band width or a bigger matrix with low band-width. Is this a correct assesment ?
In finite difference methods, compact schemes allow for higher order accuracy by solving low band-width matrices. However, the integration has to be implicit to retain efficiency.
Old   April 5, 2001, 15:30
alexy
You have to solve more equations if you use traditional fe methodology when additional test/trial functions are introduced in order to increase the order of accuracy (quadratic, cubic bases for example). The paper mentioned above uses a very different ideas and not only the matrix bandwidth, but also the number of equations to solve is the same as in lower order methods. One therefore obtains high order (lower truncation error) solution at the same computational expense as a lower order solution.
Thread Tools
Trackbacks are On
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 06:18
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
user defined function cfduser CFX 0 April 29, 2006 10:58
