April 4, 2001, 22:17 |
surface deformation
Iam a graduate student at oregon state university. Iam doing some research on the surface deformation when a molten alumina surface is impinged by an alumina droplet. Initially i have started with a water model (water droplet falling in water). I have modeled the system as multiphase lagrangian with free surface. But in my model I dont see any ripples, which is the expected deformation of the free surface (water). It would of great help for me if somebody have done similar work in droplet and free surface.
Thanks bala |
April 5, 2001, 02:44 |
Re: surface deformation
I am doing that one in 2D now, and I will extend it in 3D soon.
So, can you make a mpeg file, and send it to me, then I will send my own to you. Kim |
April 5, 2001, 12:08 |
Tell me ALOT more about your model...The more details you give the more someone can help.
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
Weld surface deformation by VOF model | minhaj_iut | FLUENT | 5 | February 26, 2017 23:51 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
