jets
Old   April 9, 2001, 05:37
Default jets
mechikel mohamed
Je travaille sur les jets turbulents à masse volumique variable confinnés avec un modèle de turbulence du second ordre(Reynolds stress model) et j'ai besoin d'une aide urgente pour acquerrir un code de calcul qui traite cette situation.
Merci
Old   April 9, 2001, 08:23
Default Re: jets - Freistrahl
Peter
Lieber Mohamed,
vielleicht wüßten einige Leute etwas über Freistrahlen und Turbulenzmodelle, aber sie verstehen die Fragen nicht.
Peter
PS. Post your questions in English!
Old   April 10, 2001, 09:37
mechikel mohamed
Hello I work on the confinned turbulent jets with variable density with a model of turbulence of the second ordre (Reynolds stress model)and I have an urgent need to acquire a computer code which treats this field.
Thanks
Old   April 11, 2001, 03:48
A.Hassaneen
I have done some good work on jet impingement using FIDAP code (FE code).
Old   April 11, 2001, 04:19
Default Re: jets - A.Hassaneen
mechikel mohamed
Hello
I would like well that you to give me more explanations on FIDAP codes, his applications.
Thanks.
Old   April 11, 2001, 04:28
A.Hassaneen
FIDAP is a finite element CFD code and it has many capabilities. As I told you, I have successfully used it in jet impingement application with free surface modeling. The other codes also can do it. It depends on what are trying to model?. By the way, FIDAP is supported by Fluent company.
Old   April 11, 2001, 10:04
mechikel mohamed
Hello
Thanks for your explanations, I ask you if possible to inform me on the way of acquiring FIDAP codes or others.
Thanks.
Old   April 12, 2001, 02:15
Hassaneen
get in contact with fluent
CFD beginner:- Help needed, general questions on Free jets? (Fluent 5.2.3) Wong, R.Y.T. Main CFD Forum 5 October 22, 2010 00:51
Creating New Solver: For particle-laden compressible jets sankarv OpenFOAM 0 April 4, 2010 18:06
MIXING OF JETS KRISHNA CHANDRAN.R FLUENT 1 September 19, 2007 14:42
Summer Course on ''Jets in Cross-Flow'' alfredo soldati Main CFD Forum 1 May 5, 2001 21:34
Laminar Coaxial Jets? Chuck Leakeas Main CFD Forum 3 April 14, 1999 14:33
