ADI Method
Old   April 18, 2001, 14:15
Default ADI Method
Paul Safier
Does anyone know of a good resource for information on how to code the ADI method. I would like to see pseudo code ideally.
Thanks...
Old   April 23, 2001, 09:42
Default Re: ADI Method
G. Brady
Paul, this code in FORTRAN may help, its based on heat transfer on a slab or material. You may need to change the loops to suit. Also, try Numerical Recipes online http://www.ulib.org/webRoot/Books/Nu...pes/bookf.html
Regards, Gavin John
CODE: ! APPLIED NUMERICAL METHODS, EXAMPLE 7.3 ! Two dimensional unsteady state heat conduction in an infinite ! bar of square cross-section, solved by the I.A.D method ! ! At time TAU = 0, the temperature is zero everywhere, and the ! faces of the bar are subsequently maintained at T = 1. ! The temperatures in the lower right-hand quadrant are printed ! every IFREQ time-steps, until the center temperature exceeds ! TMAX. !
PROGRAM ADI
IMPLICIT DOUBLE PRECISION (A-H,O-Z)
DIMENSION A(11) !COEFFICIENT VECTOR
DIMENSION B(11) !COEFFICIENT VECTOR
DIMENSION C(11) !COEFFICIENT VECTOR
DIMENSION D(11) !COEFFICIENT VECTOR
DIMENSION T(11,11) !VECTOR OF TEMPS AT GRID POINTS
DIMENSION TSTAR(11,11) !MATRIX OF TEMPS T* END OF 1/2 TAU
DIMENSION TPRIME(11) !TEMPS FROM TRIDAG
DIMENSION X(11) !VECTOR OF X CO-ORDS
!DIMENSION Y(11) !VECTOR OF Y CO-ORDS !------------------------------------------------------------ !READ AND VERIFY INPUT PARAMETERS !------------------------------------------------------------
PARAMETER (DTAU=0.05) !TIME STEP
PARAMETER (TMAX=0.95) !MAX CENTRE TEMP
PARAMETER (N=10) !NO. SPACE INCREMENTS
PARAMETER (IFREQ=1) !NUMBER OF TIMES BETWEEN SUCESSIVE..
OPEN(UNIT=6,FILE='HEATq1.DAT',STATUS='UNKNOWN') !------------------------------------------------------------ !READ AND CHECK INPUT PARAMETERS !------------------------------------------------------------
NP1=N+1
FLOATN=N
DX=1.0/FLOATN !should be n-1??
RATIO=DTAU/(DX*DX) !COURANT NUMBER
WRITE(6,*)'DTAU,DX,RATIO,TMAX,N,IFREQ'
WRITE(6,*)DTAU,DX,RATIO,TMAX,N,IFREQ !------------------------------------------------------------ !SET INITIAL AND BOUNDARY VALUES !------------------------------------------------------------
DO I=1,N
T(I,NP1)=1.0
T(NP1,I)=1.0
TSTAR(I,NP1)=1.0
TSTAR(NP1,I)=1.0
DO J=1,N
T(I,J)=0.0
TSTAR(I,J)=0.0
END DO
END DO
T(NP1,NP1)=1.0
TSTAR(NP1,NP1)=1.0 !------------------------------------------------------------ !SET COEFFICIENT ARRAYS A,B AND C !------------------------------------------------------------
B(1)=2.0*(1.0/RATIO+1.0)
F=2.0*(1.0/RATIO-1.0)
DO I=2,N
A(I)=-1.0
B(I)=B(1)
C(I)=-1.0
END DO
C(1)=-2.0
ICOUNT=0
TAU=0.0 !TIME !------------------------------------------------------------ !PERFORM CALCULATIONS OVER SUCCESSIVE TIME-STEPS !------------------------------------------------------------
4 TAU=TAU+DTAU
ICOUNT=ICOUNT+1 !------------------------------------------------------------ !COMPUTE TEMPERATURES AT END OF HALF TIME INCREMENT !(IMPLICIT BY COLUMNS) !------------------------------------------------------------
DO J=1,N
DO I=1,N
IF(J.NE.1)THEN
D(I)=T(I,J-1)+F*T(I,J)+T(I,J+1)
ELSE
D(I)=2.0*T(I,2)+F*T(I,1)
END IF
D(N)=D(N)+T(NP1,J)
END DO
CALL TRIDAG(N,A,B,C,D,TPRIME)
DO I=1,N
TSTAR(I,J)=TPRIME(I)
END DO
END DO !------------------------------------------------------------ !COMPUTE TEMPERATURE AT END OF WHOLE TIME INCREMENT !(IMPLICIT BY ROWS) !------------------------------------------------------------
DO M=1,N,1
DO J=1,N,1
PRINT*,M,J
IF(M.NE.1)THEN
D(J)=TSTAR(M-1,J)+F*TSTAR(M,J)+TSTAR(M+1,J)
ELSE
D(J)=2.0*TSTAR(2,J)+F*TSTAR(1,J)
END IF
D(N)=D(N)+TSTAR(M,NP1)
END DO
DO J=1,N
T(M,J)=TPRIME(J)
END DO
END DO !------------------------------------------------------------ !PRINT TEMPERATURES THROUGHOUT THE QUADRANT !------------------------------------------------------------
IF(ICOUNT.NE.IFREQ)THEN
IF(T(NP1,NP1).LE.TMAX)GOTO 4
!15 IF(T(1,1)-TMAX)4,4,1
ELSE
ICOUNT=0
WRITE(6,*)'AT A TIME TAU=',TAU
DO I=1,NP1
WRITE(6,*)(T(I,J),J=1,NP1)
END DO
END IF
STOP
CONTAINS !------------------------------------------------------------ !FORMAT FOR INPUT AND OUTPUT STATEMENTS !------------------------------------------------------------
SUBROUTINE TRIDAG(L,A,B,C,D,V) !------------------------------------------------------------ ! SUBROUTINE FOR SOLVING A SYSTEM OF LINEAR SIMULTANEOUS ! EQUATIONS HAVING A TRIDIAGONAL COEFFICIENT MATRIX. ! THE EQUATIONS ARE NUMBERED FROM IF THROUGH L, AND THEIR ! SUB-DIAGONAL, DIAGONAL, AND SUPER-DIAGONAL COEFFICIENTS ! ARE STORED IN THE ARRAYS A,B, AND C. THE COMPUTED ! SOLUTION VECTOR V(IF).....V(L)
DIMENSION A(1),B(1),C(1),D(1),V(1),BETA(101),GAMMA(101) !------------------------------------------------------------ !COMPUTE INTERMEDIATE ARRAYS BETA AND GAMMA !------------------------------------------------------------
BETA(1)=B(1)
GAMMA(1)=D(1)/BETA(1)
IFP1=1+1
DO I=IFP1,L
BETA(I)=B(I)-A(I)*C(I-1)/BETA(I-1)
GAMMA(I)=(D(I)-A(I)*GAMMA(I-1))/BETA(I)
END DO !------------------------------------------------------------ !COMPUTE FINAL SOLUTION VECTOR V !------------------------------------------------------------
V(L)=GAMMA(L)
LAST=L-1
DO K=1,LAST
I=L-K
V(I)=GAMMA(I)-C(I)*V(I+1)/BETA(I)
END DO
RETURN
END SUBROUTINE TRIDAG !------------------------------------------------------------
END PROGRAM ADI
Old   June 4, 2011, 11:28
irfan
irfan20uk is on a distinguished road
Hello, I need a C/C++ code of ADI method for a 2D problem. I have made mine but getting some structural artefacts, would be nice if yomebody share it so that I can compare mine with that. Thanks
irfan20uk is offline   Reply With Quote
Thread Tools
Trackbacks are On
discretizer - gmshToFoam Andyjoe Open Source Meshers: Gmsh, Netgen, CGNS, ... 13 March 14, 2012 05:35
Fluent 6.3.26 vs 12.1 and partition method Anorky FLUENT 0 April 27, 2010 10:55
Code for most powerfull FDV Method D.S.Nasan Main CFD Forum 6 September 4, 2008 02:08
Help about the preconditioner in gmres method Dan Gao Main CFD Forum 3 July 5, 2008 01:18
hess-smith method and fvm method yangqing FLUENT 0 March 20, 2002 20:25
