SIMPLE for transient NS.
Old   May 8, 2001, 06:46
Default SIMPLE for transient NS.
zhor
Hi, I heard that it is not recommended to apply SIMPLE-method to the transient Navier-Stokes? Why?
Old   May 8, 2001, 12:40
Default Re: SIMPLE for transient NS.
John C. Chien
(1). For compressible flows, the methods used are normally the so-called density-based, where the continuity equation will provide one equation for the transient density calculation. (2). For incompressible flows, there is no density transient term in the continuity equation. The normal approach is to use stream function (2-D), and vorticity-velocity (3-D) formulation, where the pressure is de-coupled from the governing equations (one does not need to solve the pressure in order to solve the velocity field). (3). The pressure-based formulation like "SIMPLE" try to retain the form of primitive variable in the governing equation (instead of the derived stream function and vorticity), and solve the unknown pressure terms (in the momentum eqautions ) iteratively through another external pressure-guessing(updating) loop. And hoping that both pressure and the velocity fields will converge to the true solutions. (4). As you can see, for the transient flows, it is easier to use the compressible, density-based approach. (both explicit-marching in time, or using implicit method in time) (5). The so-called pressure-based method for transient flows will have a lot of "guessing" (iteration) to do in looking for the solution.(both the pressure and the velocity iteratively at any time)
Old   May 10, 2001, 06:17
Kike
Hi, Z
Where have you heard this? Any reference? Kike
Thread Tools
Trackbacks are On
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 18:02
How to add correcting pressure equation in SIMPLE of MRFSimpleFOAM? renyun0511 OpenFOAM Programming & Development 0 November 4, 2010 02:38
Making SIMPLE converge faster Fabio Main CFD Forum 4 April 9, 2006 11:35
PISO vs. SIMPLE benedikt flurl Main CFD Forum 2 April 14, 2005 06:54
flow over a 2D cyl using SIMPLE T Main CFD Forum 1 January 27, 2001 08:32
