upwind v.s. chequerboard
Old   May 13, 2001, 20:16
Default upwind v.s. chequerboard
Darcy Jiang
Hi! eveybody
Does anyone know how the upwind schemes eliminate the chequerboard oscillation on pressure and velocity field? Does it mean that use upwind scheme to determine the velocity on contral volume surface?
Best regard
Darcy
Old   May 14, 2001, 05:41
Default Re: upwind v.s. chequerboard
Sebastien Perron
An upwind discretization of the advection term as nothing to do with the elimination of checkerboard board pressure solutions.
1) An upwind discretization of the advection term stabilized the solution for advection driven transport of a scalar quantity.
2). The checkerboard type solution for pressure as to do with incorrect space functions for velocity and pressure.
Old   May 14, 2001, 11:10
Anthony Wachs
Sebastien is definitively true!!
To avoid checkerboard pressure solutions, the easiest way is to use staggered grid (see Patankar) for pressure and velocity, which is equivalent to use Raviart-Thomas element for velocity and Q0 element for pressure.
Bye
Old   May 16, 2001, 07:15
Barry
Or of course if you opt for the "better" more suitable Co-located grid, you may use the so called "Rhie and Chow" interpolation. Co located grids is the obvious choice as unstructured grids may be handled without too much complications.
Old   May 19, 2001, 03:05
Tony
hi,dear Sebastien,
I have a problem about the upwind or hybrid scheme,I want to extend my code(central difference for all space derivatives) to fluid field including separation,now,I use Adams-bashforth for the convective terms[i.e.,du/dx(t+1)=3/2(du/dx(t))-1/2(du/dx(t-1))],I wonder,if I can use upwind or hybrid scheme for du/dx(t) and du/dx(t-1) to evaluate du/dx(t+1)?here,t is the time step.
thanks
2nd order upwind vs 2nd order upwind!!! Far Main CFD Forum 7 March 14, 2013 12:29
Why results differs between upwind and vanLeerV kjetil OpenFOAM Running, Solving & CFD 1 November 10, 2012 04:55
Second order upwind is not UPwind!!! Far CFX 9 May 31, 2011 08:21
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 01:50
Wrong fvm::div assembling santiagomarquezd OpenFOAM Bugs 90 December 27, 2010 12:54
