-   -   FLUENT Boundary condition problem (http://www.cfd-online.com/Forums/main/348-fluent-boundary-condition-problem.html)
Khalid November 26, 1998 19:07
Hi I really got some problem, my simulation about extinguishing a compartment gas fire with water spray droplets. the difficulties I met about swithcing on some of the model togethre in FLUENT. The models are time dependent, Dispersed phase (water spray droplets, radiation model with a combustion (high temperature around 2000K). I need to use radiation model to ge accurat result to compare it with experimental results. but To avoid making the problem complex. I thought to use wall heat flux instead of radiation. In otherwords calculating how much the radiation loss (30%) of the total heat release rate 4.6 MW which will results in 1.38 MW, and then use heat loss through the wall equivalent to this value. So, I need feedback about this and any other comments or any other solution to this problems
Sung-Eun Kim December 2, 1998 20:54
Re: FLUENT Boundary condition problem
Dear client,
Could you please contact me at sek@fluent.com ?
