Transportiveness property
Like Tree1Likes
  • 1 Post By D.M. Lipinski
Old   May 19, 2001, 12:45
Default Transportiveness property
Mehdi BEN ELHADJ
What is the meaning of the transportiveness property of a fluid flow and its relation with Peclet number ?
Old   May 19, 2001, 14:54
Default Re: Transportiveness property
John C. Chien
(1). I have never heard of such words as "transportiveness property of a fluid flow". Can you cite the source?
Old   May 20, 2001, 03:31
D.M. Lipinski
For fluid flow, transportiveness describes the influence on the upstream node on the downstream node.
For zero Peclet number (pure diffusion), the isolines of constant PHI (any field variable) around the node P are circular. The influence of PHI at P spreads equally (for constant diffusivity) in all directions.
For high Peclet numbers (assumed flow from the node P to E), PHI at P strongly influences the value of PHI at the downstream node E. But PHI at P is weakly influenced by PHI at E. The isolines of PHI at E are ellipses biased towards the upwind node P. The higher is the Peclet number the closer is the value of PHI at E to the value of PHI at P.
You should be able to see the transportive property in the numerical scheme. The coefficient matrix for a convection-diffusion problem will be unsymmetric. For the upwind node (P) the matrix coefficient (Ap-e) will include only diffusion. For the downstream node, convection and diffusion will be included in Ae-p. You can consult the description of the upwind schemes for the convection term for more information.
regards
DML
babak.mahjoub likes this.
Old   May 22, 2001, 03:51
Onno
You will find some description on Transportiveness in: An introduction to Computational Fluid Dynamics: The finite Volume Method; HK Versteeg & W Malalasekera; 1995; Longman Scientific & Technical. Pages 7, 110, 112-114, 118, 123.
As I understand it, it is a term introduced to justify upwind differencing.
Thread Tools
Trackbacks are On
does physical property in fluent depend on P or just depend T only? gsyuan FLUENT 0 December 30, 2009 22:07
Theory behind the solid domain rotation in fluid using Bets property Riken CFX 0 October 28, 2009 10:51
how to find property for compressible flow jai CFX 2 August 3, 2009 21:09
Non-Newtonian Fluids Property Ben FLOW-3D 8 April 28, 2009 10:57
URGENT custom property for UDF Sandilya Garimella FLUENT 0 May 19, 2008 12:35
