about pseudo time
Old   June 1, 2001, 04:22
Default about pseudo time
Atit Koonsrisuk
Dear sir,
I have read 'A Time-Accurate Algorithm for Chemical
Non-Equiplibrium Vicous Flows at All Speeds" of 'J. S. Shuen et. al.
and I have some problems but I cannot contact the authors. Could you
give me some suggestions for the following questions please? --------------------------------------------------------------------
1. After doing some mathematical manipulations, we obtain the
Navier-Stokes equations in a conservation form in curvilinear
coordinates:
(P)[d(Q_hat)/d(tou)] + [d(Q_star)/d(t)] + [d(E_star)/d(sine)] +
[d(F_star)/d(eta)] = H
where Q_hat is J*[ p_g u v h]_transpose
tou is the pseudo time
t is the physical time
H is the source term
The author say that "the eigenvalues (in the sine-direction) in
the pseudo-time can be obtained from the matrix [(P_transpose)*A],
where A is the jacobian [d(E_star)/d(Q_hat)]."
My problem is what do I do with the eigenvalues obtained?
Actually I don't know why we have to find them. Use them to find the
delta_tou? How? and do I have to consider the eigenvalues in
eta-direction? What is the different influent on the pseudo-time term
of these two set of eigenvalues? -----------------------------------------------------------------------
2.After discretization, the dual time-stepping integration
method is chosen. (Actually I still have the problem how to apply this
method to this equation, the author don't say in deep detail.)
The author say that "the physical time step size, delta_t, is
determined based on the characteristic evolution of the unsteady flow
under consideration, the pseudo-time step size, delta_tou, is
determined based on the numerical stability of the algorithm and can be
adjusted to give the optimum convergence rate for the pseudo-time
iteration procedure."
My problem is I do not understand how to find delta_t and
delta_tou, and how to adjust it? Could you give me some explaination or
some examples please? ----------------------------------------------------------------------
3. The author said that he used a modified strongly implicit
procedure. Could you give me some explaination about this procedure
please or give me some examples of how to apply them please? ---------------------------------------------------------------------
Thank you very much sir.
Best regards,
Atit Koonsrisuk
Old   June 1, 2001, 12:51
Default Re: about pseudo time
kalyan
The strong implicit procedure (SIP) is also called the Stone method in applied math. circles. It is basically a kind of incomplete cholesky algorithm. You can find it explained in the book by Ferziger and Peric.
Time step size and max iterations per time step pUl| FLUENT 33 October 23, 2020 22:50
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
pseudo Time stepping vs real time stepping nileshjrane Main CFD Forum 0 October 19, 2010 05:13
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
