May 23, 2001, 19:05 |
URGENT>> error message from ICEM CFD
I use WinNT 4 workstation & Icemcfd mesh editor 4.1. I'm working on the 2Dpipe junction hexa tutorial from icemcfd site, and every time I choose to start hexa interactive and press with No Blocking button in the blocking file window, I get the following error message>> while a small window titled guibase is initiating it gives this error>>
************************ Error invalid command name".e.buts.m" while executing "$fname.m add radiobutton -label [lindex $ 0] -variable project_type -vlaue [lindex $ 1] -command "mesh_up_to_date 1; change_projection"" (procedure "make_display_window"line 172) invoked from within "make_display_window" (procedure "make_tool_windows"line 2) invoked from within "make_tool_windows" ************************ Thanks in advance for any help you may give. Danial |
May 25, 2001, 16:56 |
Problem Solved, Thanks to Ben
Thanks to Ben Problem was solved. it was due to bad resolution 600x800 and may be bad graphics card. Thanks Ben for all your attempts to help others. Danial.
[ICEM] Icem CFD on Linux | mechanicaldesign | ANSYS Meshing & Geometry | 7 | March 11, 2021 19:44 |
Need help icem cfd | kakhtar | ANSYS Meshing & Geometry | 25 | January 31, 2017 01:09 |
Transport mesh from ICEM CFD, to Fluent, to Sysnoise | Wieland | FLUENT | 2 | April 15, 2012 06:28 |
[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent | ivanddd | ANSYS Meshing & Geometry | 1 | February 3, 2011 00:51 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
