Someone helps me!
Old   May 27, 2001, 13:52
Default Someone helps me!
Johnny Lam
I'm a student. In the beginning of solving cfd problem, I met some troubles: Although I studied aerodynamics, FEM, but writting myself a code to solve "flow over a cylinder" (in ANSYS-flotran), I saw that my results weren't exact as experimental. I think that I need some simple codes for reference. They must simple,easy for a student who has just known Flotran-Ansys. Someone can let me know where can i get some codes? Thank you very much.
PS: I sent also my code for problem "flow over a cylinder", please tell me what is is wrong,how can i rewrite...?
!Re = 3.09e-6 (To compare with Cd in the book:FUNDAMENTAL OF AERODYNAMICS. JOHN ANDERSON) !air density = 1.23 !Velocity = 45 !Diameter = 1 !Vicousity coeifficient = 1.789e-5 !rectangle size is 150x100
/unit,si /prep7 rectng,0,150,0,100 local,11,0,75,50,0,,,,1,1 csys,11 wpcsys,-1 pcirc,0.5,0,0,360 csdele,11,,1 aovlap,all adel,2 csys,0 wpcsys,-1 lsel,s,,,1,3,2 lesize,all,3,,,1 lsel,s,,,2,4,2 lesize,all,2,,,1 lsel,s,,,5,8 lesize,all,,,64,,1 allsel et,1,141 amesh,all
dl,4,,vx,45,0 !Velocity at inlet line = 45 dl,4,,vy,0,0 dl,2,,pres,0,0 !Pressure at outlet = 0 dl,1,,vx,0,1 !Boundary is in condition of a windtunel dl,1,,vy,0,1 dl,3,,vx,0,1 dl,3,,vy,0,1
dl,5,,vx,0,1 !lines on circle, Vx=Vy=0, end line selected dl,5,,vy,0,1 dl,6,,vx,0,1 dl,6,,vy,0,1 dl,7,,vx,0,1 dl,7,,vy,0,1 dl,8,,vx,0,1 dl,8,,vy,0,1
/solu FLDATA5,OUTP,PCOE,1 !add a pressure coefficient DOF fldata1,solu,turb,1 flda,iter,exec,500
flda,prot,visc,constant !fluid property, constant flda,prot,dens,constant fldata,nomi,dens,1.23 fldata,nomi,visc,1.789e-5 allsel solve
Old   May 27, 2001, 20:46
Default Re: Someone helps me!
John C. Chien
(1). I could not understand your message. (2). The flow over a cylinder has been studied for many years, so there should be plenty of information available out there on the subject. (3). My suggestion is: write down the governing eqautions. If you are interested in 2-D, laminar flow, then convert the equations into vorticity-stream function formulation. Then you should be able to solve this set of equations by reading some CFD books, or related published papers. (4). It is a fairly standard test case. The important thing to remember is that, you must define your problem in terms of the Reynolds number, which will determine the characteristics of the solution. (Don't try to push it into turbulent flow regime at this point of study.) (5). It is also a good idea to have a good CFD teacher, so that you can follow his foot steps. CFD is not a DIY project yet.
Old   May 27, 2001, 23:56
Johnny Lam
I wrote a code in ANSYS-FLOTRAN to solve "flow over a circular cylinder" but solution was very diffrent with experience. So I need some codes for reference. In my country, no one know well about ANSYS-FLOTRAN, so I cannot ask someone (my teacher said also). Could you give me the codes for this problem or the address for download them? Excuse-me for my poor English.
Old   May 28, 2001, 08:51
Peter Attar
ANSYS has a group on www.egroups.com...go to this site and sign up for the group,check the archives first for messages on this topic. If you don't see any posts on this subject post a message to the group with your name and school and a detailed explanation of your problem and someone is sure to be able to help you.
Old   May 29, 2001, 05:12
S.P.Asok
May I know what is a DIY project.
Old   May 29, 2001, 05:47
John C. Chien
(1). DIY="Do It Yourself"=All you need to know is how to use a screw driver and a hammer.(2). (!DIY)=Need to receive professional training first.
Old   May 29, 2001, 07:07
S.P.Asok
I do totally agree that CFD is not a DIY/LIY(Learn It Yourself)affair.I have been thinking that it was my view, but it seems many share the same view.
Old   June 1, 2001, 06:54
rupa dutta
John
I connot agree more with you.
Many (most) of us buy fluid flow s/w package as a DIY kit and 'play' with it. Well, if you can set up a menu ( geometry, grid etc.), it'll give you a colourful flow 'picture'.
Thanks. I learnt witty term.
rupa
Thread Tools
Trackbacks are On
Polyflow helps natuan74 FLUENT 0 February 12, 2010 01:26
please please i need urgent helps ahmed FLUENT 3 August 22, 2007 03:12
please please i need urgent helps ahmed FLUENT 0 August 5, 2007 09:50
A strange conpiling error! Need helps, urgent!!! Anh FLUENT 3 May 12, 2006 04:45
how cfd package helps to solve problems in I.C eng vivekanand Main CFD Forum 0 October 27, 2004 05:10
