aerodynamic designing
Old   May 28, 2001, 07:55
Default aerodynamic designing
Abhishek Gupta
I am a student of Indian Institute of Technology Guwahati(India) doing my B.tech in Mechanical Engg. in IInd year.I am interested in the field of CFD and aerodynamic designing.I have done some work in incompressible jets and recently working in parallelising the SIMPLE algorithm using super computer. Kindly advice me that how should go about in the field of aerodynamic designing. anticipating a reply abhishek gupta
Old   May 28, 2001, 13:07
Default Re: aerodynamic designing
rajeev
Hi Abhishek:
1) Well, you didn't mention how much you know about aerodynamics 2) firstly i would say, u need to go thru with basic aerodynamics fundamentals, refer Anderson's books. 3). Well as you mentioned, you have worked on SIMPLE which is an incompressible flow alogorithm. But most of aerodynamic problems are compressible flow. 4) Compressible flow algorithms are somewhat very different to incompressible flow one. 5) i would suggest, firstly you need to study basic aerodyamics and compressible flow CFD. There are numerous literatures on both fields.
regards, rajeev
Old   May 28, 2001, 16:40
clifford bradford
I would recommend separating the CFD from the aero design. Take some classes at your school in aerodynamics and read whatever you can on the subject. It seems like you have a lot of skill in CFD; you should try to gain similar skill in aerodynamics.
Old   May 29, 2001, 08:09
Abhijit Tilak
Hi abhishek,
Well First of all CDF & aerodynamics do not mean one & same thing. The algorithm ur are talking about is actually not meant for compressible flows which is a hallmark of areodynamics. Mech Engg use SIMPLE becsuse they deal primarily with incomp flows. If ur using structured grids you can use Red -Black Gauss siedel /Alternating Line Zebra algorithms along with highest optimization level in unix/Linux f77 complier & parallelise ur code ( I did that). Ofcourse ur machine must have >1 CPU's. Refer "Multigrid Tutorial " by William Briggs for algo details.
Hope this helps
Abhijit Tilak
Aero Engg Dept
IIT Bombay.
Old   May 30, 2001, 02:21
teja rao
dear abhishek u don't know whats aerodyanamic designing. first,read it and SIMPLE deals with incompressible fluids which is not required in this. you rather seek proper guidance from your faculty. otherwise u can keep in touch with me i'll guide you so....all the best and wish that you are successful in your future endeavour. bye teja
Calculate aerodynamic coefficients with openfoam using only opensource programs Xwang OpenFOAM 20 May 20, 2016 11:26
Aerodynamic noise analysis with CFX famarcfd Main CFD Forum 0 December 14, 2010 07:53
Aerodynamic noise analysis with CFX famarcfd ANSYS 0 December 13, 2010 06:27
Computing aerodynamic coefficients on bidimensional sections in 3D problems Aragon FLUENT 0 July 22, 2009 04:07
aerodynamic designing Abhishek Gupta FLUENT 1 June 7, 2001 23:19
