Behaviour of a Submarine at Earthquake
Old   June 19, 2001, 14:02
Default Behaviour of a Submarine at Earthquake
daniel troni
Hi All-
Any Pointer of software or research for the subject :
Modelisation The Behaviour of A Submarine under a 7-8 Richter Seismic/Eartquake While The Submarine is going at his Max Speed to DOWN or UP..Or to define the dangerous mouvements while the earhtquake occurs...Or the identification, if it is same for an underwater Bomb Shock ?
thanks for any help
DANI
Old   June 19, 2001, 17:04
Default Re: Behaviour of a Submarine at Earthquake
John C. Chien
(1). I have not seen any report of earth quake and whales. (2). I have seen reports that people are using water tank under the building to absorb the energy of earth quake (to reduce the damage to the building). (3). So, in ocean with a lot of water around the submarine, the earth quake should have minimum impact on the submarine. (4). My experience of the earth quake in a moving car is similar to the high side wind. Underwater Bomb Shock is a different thing. It will create very high pressure wave, which is different from the low frequency earth quake.
Strange behaviour when using LienCubicKE and NonlinearKEShih hani OpenFOAM Running, Solving & CFD 20 March 6, 2013 10:06
Unstable behaviour after long period of stablility plunge11 FLUENT 1 April 6, 2011 09:15
strange behaviour of GGI in parallel on axis symmetrical case A.Devesa OpenFOAM Running, Solving & CFD 0 April 6, 2010 03:58
Fluent strange behaviour (occasional divergence) muketa FLUENT 0 March 18, 2010 04:55
Modelling Industrial cyclone behaviour Günther Hasse Main CFD Forum 3 October 12, 1999 19:34
