How can I modify the codes?
Old   June 1, 2001, 05:43
Default How can I modify the codes?
JohnnyLam
I wrote codes below to simulate the flow over an circular cylinder. But the Cd was not exact to 0.6 for Re=1e7. Can you teach me what are errors, how can I improve the results. Thanks. ( johnny@vol.vnn.vn)
CODES: !Re = 3.09e-6 !air density = 1.23 !Velocity = 45 !Diameter = 1 !Vicousity coeifficient = 1.789e-5 !divisions of 1/4 circle = 64 !rectangle-wind tunnel size is 150x100 /unit,si /prep7 rectng,0,150,0,100 local,11,0,75,50,0,,,,1,1 csys,11 wpcsys,-1 pcirc,0.5,0,0,360 aovlap,all adel,2 !circle is deleted lsel,s,,,1,3,2 lesize,all,3,,,1 lsel,s,,,2,4,2 lesize,all,2,,,1 lsel,s,,,5,8 lesize,all,,,64,,1 allsel et,1,141 !mshape,0 !try triangle mesh amesh,all dl,4,,vx,45,0 !line 4, inlet, Vx = 45, Vy = 0 dl,4,,vy,0,0 vv dl,2,,pres,0,0 !outlet, P=0 dl,1,,vx,0,1 !line 1 - bottom dl,1,,vy,0,1 dl,3,,vx,0,1 !line3 - top line dl,3,,vy,0,1 dl,5,,vx,0,1 !lines on circle, dl,5,,vy,0,1 dl,6,,vx,0,1 dl,6,,vy,0,1 dl,7,,vx,0,1 dl,7,,vy,0,1 dl,8,,vx,0,1 dl,8,,vy,0,1
/solu FLDATA5,OUTP,PCOE,1 !add a pressure coefficient DOF fldata1,solu,turb,1 !turbular solution flda,iter,exec,1000 FLDATA3,TERM,PRES,1e-004 FLDATA3,TERM,TEMP,1e-004 flda,prot,visc,constant !fluid property, constant flda,prot,dens,constant fldata,nomi,dens,1.23 fldata,nomi,visc,1.789e-5 allsel solve FINISH /POST1 SET,LAST PLNSOL,PCOE,,0, lsel,s,,,5,8 nsll,s,1 INTSRF,PRES
Old   June 1, 2001, 14:29
Default Re: How can I modify the codes?
clifford bradford
I assume this is a ANSYS Flotran?
Old   June 1, 2001, 14:46
Adrin Gharakhani
Hopefully, this is a typo! you should have 3.09e6. As for the rest, you are not "writing" a code as you claim, but just inputting data. As such, it is difficult to answer your general question without knowing the details.
Adrin Gharakhani
Is it worth it? Jason Bardis Main CFD Forum 47 July 27, 2011 04:52
Comparison of CFD Codes Kerem Main CFD Forum 9 May 9, 2003 04:29
New List of Free CFD Codes Bert Laney Main CFD Forum 5 September 15, 1999 15:24
