June 5, 2001, 11:40 |
Gas-liquid reactor
Hi, everyone,
I am solving the mixing of gas-liquid system in a small reactor. In my experimental work, I found the diameter of some gas bubbles was about 1.5 mm, however, I divided my reactor into thousands of cells, whose dimension was 1.0 mm, which means that the diameter of gas bubbles from CFD calculation are different from my experiments. I think the gas volume fraction will be different too. Anyone has some ideas about how to solve this problem? thanks in advance. |
June 5, 2001, 16:03 |
Re: Gas-liquid reactor
I am just curious, could you tell me what cfd code are you using ?
Thank you Danny |
June 6, 2001, 07:03 |
I am using CFX4.1. You know, I intended to solve the problem with a small reactor ( the diameter is 0.008 m ) and I had divided the reactor into thousands of cells ( the dimension is about 0.0002 m), however, the gas bubble diameter may be greater than the size of a cell, which means you can not solve the gas volume fraction in a so small cell. That is my problem. Tiger |
June 6, 2001, 12:37 |
May I suggest you to use CFX discussion forum. I believe someone over there can help you. Danny |
June 6, 2001, 23:46 |
The disperse phase models in CFX-4 are based on a source term in the momentum equation which couples the two phases and represents the drag force on the bubbles at the slip velocity (Continuous Phase Velocity-Disperse Phase Velocity).
There is no need to resolve individual bubbles because the model inherently assumes that you are not, and that the bubbles themselves behave as if they are a single fluid. The only reason you should need to worry about the bubble diameter is it's effect on the source term coefficient, or drag coefficient in this case. |
June 7, 2001, 08:05 |
Hi, Dan Williams,
You are right, in my case, how to calculate the drag cofficient is my problem. Do you have any idea about it? Tiger |
June 7, 2001, 23:34 |
If you enter the particle diameter and you are running the continuous-disperse model, then you have a selection of models for the drag coefficient. I can't remember the exact formulation for the source term off the top of my head but it is something like: 1/2*bulkdensity*Cd*particlediameter^2*Uslip^2/(ralpha*rbeta) (this is just a guess). There are several correleations for Cd in this case. One is Schiller Naumann I beleive. There are others that might be more appropriate to your application. Read the section on multiphase flow in the CFX-4 manual.
Dan. |
June 11, 2001, 05:31 |
Hello, Dan,
I hope my problem is that the diameter is changing from point to point, so I have to calculate the bubble diameter at first, however, the diameter of the bubble mayber greater than the dimension of the control cell. If I can get a reasonable bubble diameter, so all of the problem will be solved. |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Gas dissolution from liquid phase with CFX | Roger Young | CFX | 2 | May 6, 2008 07:37 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
