Thermal modeling of a Al case
Old   July 6, 2001, 14:41
Default Thermal modeling of a Al case
Michael Linderman
I am trying to conduct a thermal analysis of an aluminum case with a forced air heat exchanger. I am new to CFD and FEA and am not quite sure how to proceed.
Particularly I am unsure about boundary conditions, how to model the effects the fan, and how to account for the effects of the case's inner chassis.
I have access to COSMOS/WORKS that I am trying to use for the analysis. Is this the best software? Is there something better? What would be a good approach to take with this problem?
Any tips/hints/suggestions would be much appreciated.
Thanks, Michael Linderman
Old   July 6, 2001, 15:27
Default Re: Thermal modeling of a Al case
John C. Chien
(1). Find a consultant, and discuss your problem with him.
Old   July 6, 2001, 16:23
Alton J. Reich
Michael,
This is one instance when I fully agree with John .
Our CFD-ACE+ code is very good for coupling a flow solution with heat transfer in solids. I'd be happy to discuss your problem with you. Feel free to e-mail me or give me a call at 256-726-4919.
Regards, Alton
Old   July 6, 2001, 18:18
John C. Chien
(1). I am just an ordinary person, trying not to hide the ugly facts. (2). If GE and Honeywell merger case can fail, then dot.com failure is not unusual. (3). At least, this forum is still alive, longer than the merger case, or many of the dot.com business. (4). If you put your dedication in it, you will get the very important "feeling and timing", which is essential for survival of business. (5). When a company is busy calculating numbers, it is heading to problems.
Thermal Resistance Modeling of Active Heat Sinks D.Castle FloEFD, FloWorks & FloTHERM 3 August 1, 2011 06:27
modeling thermal resistance in Fluent? gholamghar FLUENT 1 August 28, 2010 12:07
Need help to open an OpenFoam case with Paraviw aaurouss OpenFOAM 2 July 6, 2009 13:18
Short Course: Computational Thermal Analysis Dean S. Schrage Main CFD Forum 11 September 27, 2000 17:46
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
