EULER-Forward-Method
Old   June 10, 2001, 03:40
Default EULER-Forward-Method
freak
I am a stupid student looking out for help. The task is: Draw up a computerprogram in a programming language of your choice (delphi, fortran,...) by which you will be able to analyse the mistakes and stability of an wearing off process. Given is the equation: du/dt=d2u/du2 (2 means square) Please use for the discretization the explicit Euler-Forward-method. The distribution of the beginning looks like a sine oscillation. The abscissa is standardized: x0=0 x1=1 The locas increment is dx=0,002. By using the following increments in time examine the stability of calculation. increment in time dt : dt/(dx)^2 ---------------------------------------- 0,000002 : 0,5 2,0004E-6 : 0,5001 2,004E-6 : 0,501 2,04E-6 : 0,51 1,96E-6 : 0,49 1,8E-6 : 0,45 1,6E-6 : 0,4 0,8E-6 : 0,2 0,4E-6 : 0,1
Give a statement about the precision resp. the number of itterations to reach a mistake less than 0,000001.
Depict (graphical) the trend of the mistake in dependence on the number of itterations in a loarithmic coordinate system for the cases listed in the table ahead specialy for x=1/4.
Depict the results of the calculation.
Please help me with this problem.
It would be nice if anyone is able to send me a program source code for the Euler-Forward-method. Or please tell me an good webpage where I can find somthing to solve my problem.
Thanx!!!
Old   June 10, 2001, 14:23
Default Re: EULER-Forward-Method
John C. Chien
(1). Read the book,"Applied Numerical Methods", by Brice Carnahan, H.A. Luther, and James O. Wilkes. (2).Chapter 7, Approximation of the solution of partial differential equations. (methods, Fortran codes included)
Old   June 11, 2001, 19:12
Mr. Bee
Here you go.
SUBROUTINE EULER(A,B,M,MBDCND,BDA,BDB,C,D,N,NBDCND,BDC,BDD,
1 ELMBDA,F,IDIMF,PERTRB,IERROR,W)
DIMENSION F(IDIMF,1)
DIMENSION BDA(1) ,BDB(1) ,BDC(1) ,BDD(1) ,
1 W(1) C C CHECK FOR INVALID PARAMETERS. C
IERROR = 0
IF (A .LT. 0.) IERROR = 1
IF (A .GE. B) IERROR = 2
IF (MBDCND.LE.0 .OR. MBDCND.GE.7) IERROR = 3
IF (C .GE. D) IERROR = 4
IF (N .LE. 3) IERROR = 5
IF (NBDCND.LE.-1 .OR. NBDCND.GE.5) IERROR = 6
IF (A.EQ.0. .AND. (MBDCND.EQ.3 .OR. MBDCND.EQ.4)) IERROR = 7
IF (A.GT.0. .AND. MBDCND.GE.5) IERROR = 8
IF (MBDCND.GE.5 .AND. NBDCND.NE.0 .AND. NBDCND.NE.3) IERROR = 9
IF (IDIMF .LT. M+1) IERROR = 10
IF (M .LE. 3) IERROR = 12
IF (IERROR .NE. 0) RETURN
MP1 = M+1
DELTAR = (B-A)/FLOAT(M)
DLRBY2 = DELTAR/2.
DLRSQ = DELTAR**2
NP1 = N+1
DELTHT = (D-C)/FLOAT(N)
DLTHSQ = DELTHT**2
NP = NBDCND+1 C C DEFINE RANGE OF INDICES I AND J FOR UNKNOWNS U(I,J). C
MSTART = 2
MSTOP = MP1
GO TO (101,105,102,103,104,105),MBDCND 101 MSTOP = M
GO TO 105 102 MSTART = 1
GO TO 105 103 MSTART = 1 104 MSTOP = M 105 MUNK = MSTOP-MSTART+1
NSTART = 1
NSTOP = N
GO TO (109,106,107,108,109),NP 106 NSTART = 2
GO TO 109 107 NSTART = 2 108 NSTOP = NP1 109 NUNK = NSTOP-NSTART+1 C C DEFINE A,B,C COEFFICIENTS IN W-ARRAY. C
ID2 = MUNK
ID3 = ID2+MUNK
ID4 = ID3+MUNK
ID5 = ID4+MUNK
ID6 = ID5+MUNK
A1 = 2./DLRSQ
IJ = 0
IF (MBDCND.EQ.3 .OR. MBDCND.EQ.4) IJ = 1
DO 110 I=1,MUNK
R = A+FLOAT(I-IJ)*DELTAR
J = ID5+I
W(J) = R
J = ID6+I
W(J) = 1./R**2
W(I) = (R-DLRBY2)/(R*DLRSQ)
J = ID3+I
W(J) = (R+DLRBY2)/(R*DLRSQ)
J = ID2+I
W(J) = -A1+ELMBDA 110 CONTINUE
GO TO (114,111,112,113,114,111),MBDCND 111 W(ID2) = A1
GO TO 114 112 W(ID2) = A1 113 W(ID3+1) = A1 114 CONTINUE C C ENTER BOUNDARY DATA FOR R-BOUNDARIES. C
GO TO (115,115,117,117,119,119),MBDCND 115 A1 = W(1)
DO 116 J=NSTART,NSTOP
F(2,J) = F(2,J)-A1*F(1,J) 116 CONTINUE
GO TO 119 117 A1 = 2.*DELTAR*W(1)
DO 118 J=NSTART,NSTOP
F(1,J) = F(1,J)+A1*BDA(J) 118 CONTINUE 119 GO TO (120,122,122,120,120,122),MBDCND 120 A1 = W(ID4)
DO 121 J=NSTART,NSTOP
F(M,J) = F(M,J)-A1*F(MP1,J) 121 CONTINUE
GO TO 124 122 A1 = 2.*DELTAR*W(ID4)
DO 123 J=NSTART,NSTOP
F(MP1,J) = F(MP1,J)-A1*BDB(J) 123 CONTINUE C C ENTER BOUNDARY DATA FOR THETA-BOUNDARIES. C 124 A1 = 1./DLTHSQ
L = ID5-MSTART+1
LP = ID6-MSTART+1
GO TO (134,125,125,127,127),NP 125 DO 126 I=MSTART,MSTOP
J = I+LP
F(I,2) = F(I,2)-A1*W(J)*F(I,1) 126 CONTINUE
GO TO 129 127 A1 = 2./DELTHT
DO 128 I=MSTART,MSTOP
J = I+LP
F(I,1) = F(I,1)+A1*W(J)*BDC(I) 128 CONTINUE 129 A1 = 1./DLTHSQ
GO TO (134,130,132,132,130),NP 130 DO 131 I=MSTART,MSTOP
J = I+LP
F(I,N) = F(I,N)-A1*W(J)*F(I,NP1) 131 CONTINUE
GO TO 134 132 A1 = 2./DELTHT
DO 133 I=MSTART,MSTOP
J = I+LP
F(I,NP1) = F(I,NP1)-A1*W(J)*BDD(I) 133 CONTINUE 134 CONTINUE C C ADJUST RIGHT SIDE OF EQUATION FOR UNKNOWN AT POLE WHEN HAVE C DERIVATIVE SPECIFIED BOUNDARY CONDITIONS. C
IF (MBDCND.GE.5 .AND. NBDCND.EQ.3)
1 F(1,1) = F(1,1)-(BDD(2)-BDC(2))*4./(FLOAT(N)*DELTHT*DLRSQ) C C ADJUST RIGHT SIDE OF SINGULAR PROBLEMS TO INSURE EXISTENCE OF A C SOLUTION. C
PERTRB = 0.
IF (ELMBDA) 144,136,135 135 IERROR = 11
GO TO 144 136 IF (NBDCND.NE.0 .AND. NBDCND.NE.3) GO TO 144
S2 = 0.
GO TO (144,144,137,144,144,138),MBDCND 137 W(ID5+1) = .5*(W(ID5+2)-DLRBY2)
S2 = .25*DELTAR 138 A2 = 2.
IF (NBDCND .EQ. 0) A2 = 1.
J = ID5+MUNK
W(J) = .5*(W(J-1)+DLRBY2)
S = 0.
DO 140 I=MSTART,MSTOP
S1 = 0.
IJ = NSTART+1
K = NSTOP-1
DO 139 J=IJ,K
S1 = S1+F(I,J) 139 CONTINUE
J = I+L
S = S+(A2*S1+F(I,NSTART)+F(I,NSTOP))*W(J) 140 CONTINUE
S2 = FLOAT(M)*A+DELTAR*(FLOAT((M-1)*(M+1))*.5+.25)+S2
S1 = (2.+A2*FLOAT(NUNK-2))*S2
IF (MBDCND .EQ. 3) GO TO 141
S2 = FLOAT(N)*A2*DELTAR/8.
S = S+F(1,1)*S2
S1 = S1+S2 141 CONTINUE
PERTRB = S/S1
DO 143 I=MSTART,MSTOP
DO 142 J=NSTART,NSTOP
F(I,J) = F(I,J)-PERTRB 142 CONTINUE 143 CONTINUE 144 CONTINUE C C MULTIPLY I-TH EQUATION THROUGH BY (R(I)*DELTHT)**2. C
DO 146 I=MSTART,MSTOP
K = I-MSTART+1
J = I+LP
A1 = DLTHSQ/W(J)
W(K) = A1*W(K)
J = ID2+K
W(J) = A1*W(J)
J = ID3+K
W(J) = A1*W(J)
DO 145 J=NSTART,NSTOP
F(I,J) = A1*F(I,J) 145 CONTINUE 146 CONTINUE
W(1) = 0.
W(ID4) = 0. C C CALL GENBUN TO SOLVE THE SYSTEM OF EQUATIONS. C
CALL GENBUN (NBDCND,NUNK,1,MUNK,W(1),W(ID2+1),W(ID3+1),IDIMF,
1 F(MSTART,NSTART),IERR1,W(ID4+1))
IWSTOR = W(ID4+1)+3.*FLOAT(MUNK)
GO TO (157,157,157,157,148,147),MBDCND C C ADJUST THE SOLUTION AS NECESSARY FOR THE PROBLEMS WHERE A = 0. C 147 IF (ELMBDA .NE. 0.) GO TO 148
YPOLE = 0.
GO TO 155 148 CONTINUE
J = ID5+MUNK
W(J) = W(ID2)/W(ID3)
DO 149 IP=3,MUNK
I = MUNK-IP+2
J = ID5+I
LP = ID2+I
K = ID3+I
W(J) = W(I)/(W(LP)-W(K)*W(J+1)) 149 CONTINUE
W(ID5+1) = -.5*DLTHSQ/(W(ID2+1)-W(ID3+1)*W(ID5+2))
DO 150 I=2,MUNK
J = ID5+I
W(J) = -W(J)*W(J-1) 150 CONTINUE
S = 0.
DO 151 J=NSTART,NSTOP
S = S+F(2,J) 151 CONTINUE
A2 = NUNK
IF (NBDCND .EQ. 0) GO TO 152
S = S-.5*(F(2,NSTART)+F(2,NSTOP))
A2 = A2-1. 152 YPOLE = (.25*DLRSQ*F(1,1)-S/A2)/(W(ID5+1)-1.+ELMBDA*DLRSQ*.25)
DO 154 I=MSTART,MSTOP
K = L+I
DO 153 J=NSTART,NSTOP
F(I,J) = F(I,J)+YPOLE*W(K) 153 CONTINUE 154 CONTINUE 155 DO 156 J=1,NP1
F(1,J) = YPOLE 156 CONTINUE 157 CONTINUE
IF (NBDCND .NE. 0) GO TO 159
DO 158 I=MSTART,MSTOP
F(I,NP1) = F(I,1) 158 CONTINUE 159 CONTINUE
W(1) = IWSTOR
RETURN
END
Old   June 12, 2001, 01:22
freak
tahnx for answering, but i can not refer the variables. that kind of programing language is it?
Old   June 12, 2001, 09:19
Mr. Bee
ax++ version 3.125
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
population balance with and Euler Euler method. thomas CFX 3 August 30, 2011 19:20
population balance with and Euler Euler method. thomas Main CFD Forum 0 May 7, 2004 07:58
population balance with and Euler Euler method. thomas FLUENT 0 May 7, 2004 07:57
Unstructured Multigrid Method for Euler equations Jian Xia Main CFD Forum 8 December 20, 1999 12:31
