EULER-Forward-Method
I am a stupid student looking out for help. The task is: Draw up a computerprogram in a programming language of your choice (delphi, fortran,...) by which you will be able to analyse the mistakes and stability of an wearing off process. Given is the equation: du/dt=d2u/du2 (2 means square) Please use for the discretization the explicit Euler-Forward-method. The distribution of the beginning looks like a sine oscillation. The abscissa is standardized: x0=0 x1=1 The locas increment is dx=0,002. By using the following increments in time examine the stability of calculation. increment in time dt : dt/(dx)^2 ---------------------------------------- 0,000002 : 0,5 2,0004E-6 : 0,5001 2,004E-6 : 0,501 2,04E-6 : 0,51 1,96E-6 : 0,49 1,8E-6 : 0,45 1,6E-6 : 0,4 0,8E-6 : 0,2 0,4E-6 : 0,1
Give a statement about the precision resp. the number of itterations to reach a mistake less than 0,000001. Depict (graphical) the trend of the mistake in dependence on the number of itterations in a loarithmic coordinate system for the cases listed in the table ahead specialy for x=1/4. Depict the results of the calculation. Please help me with this problem. It would be nice if anyone is able to send me a program source code for the Euler-Forward-method. Or please tell me an good webpage where I can find somthing to solve my problem. Thanx!!! |
Re: EULER-Forward-Method
(1). Read the book,"Applied Numerical Methods", by Brice Carnahan, H.A. Luther, and James O. Wilkes. (2).Chapter 7, Approximation of the solution of partial differential equations. (methods, Fortran codes included)
Here you go.
SUBROUTINE EULER(A,B,M,MBDCND,BDA,BDB,C,D,N,NBDCND,BDC,BDD, 1 ELMBDA,F,IDIMF,PERTRB,IERROR,W) DIMENSION F(IDIMF,1) DIMENSION BDA(1) ,BDB(1) ,BDC(1) ,BDD(1) , 1 W(1) C C CHECK FOR INVALID PARAMETERS. C IERROR = 0 IF (A .LT. 0.) IERROR = 1 IF (A .GE. B) IERROR = 2 IF (MBDCND.LE.0 .OR. MBDCND.GE.7) IERROR = 3 IF (C .GE. D) IERROR = 4 IF (N .LE. 3) IERROR = 5 IF (NBDCND.LE.-1 .OR. NBDCND.GE.5) IERROR = 6 IF (A.EQ.0. .AND. (MBDCND.EQ.3 .OR. MBDCND.EQ.4)) IERROR = 7 IF (A.GT.0. .AND. MBDCND.GE.5) IERROR = 8 IF (MBDCND.GE.5 .AND. NBDCND.NE.0 .AND. NBDCND.NE.3) IERROR = 9 IF (IDIMF .LT. M+1) IERROR = 10 IF (M .LE. 3) IERROR = 12 IF (IERROR .NE. 0) RETURN MP1 = M+1 DELTAR = (B-A)/FLOAT(M) DLRBY2 = DELTAR/2. DLRSQ = DELTAR**2 NP1 = N+1 DELTHT = (D-C)/FLOAT(N) DLTHSQ = DELTHT**2 NP = NBDCND+1 C C DEFINE RANGE OF INDICES I AND J FOR UNKNOWNS U(I,J). C MSTART = 2 MSTOP = MP1 GO TO (101,105,102,103,104,105),MBDCND 101 MSTOP = M GO TO 105 102 MSTART = 1 GO TO 105 103 MSTART = 1 104 MSTOP = M 105 MUNK = MSTOP-MSTART+1 NSTART = 1 NSTOP = N GO TO (109,106,107,108,109),NP 106 NSTART = 2 GO TO 109 107 NSTART = 2 108 NSTOP = NP1 109 NUNK = NSTOP-NSTART+1 C C DEFINE A,B,C COEFFICIENTS IN W-ARRAY. C ID2 = MUNK ID3 = ID2+MUNK ID4 = ID3+MUNK ID5 = ID4+MUNK ID6 = ID5+MUNK A1 = 2./DLRSQ IJ = 0 IF (MBDCND.EQ.3 .OR. MBDCND.EQ.4) IJ = 1 DO 110 I=1,MUNK R = A+FLOAT(I-IJ)*DELTAR J = ID5+I W(J) = R J = ID6+I W(J) = 1./R**2 W(I) = (R-DLRBY2)/(R*DLRSQ) J = ID3+I W(J) = (R+DLRBY2)/(R*DLRSQ) J = ID2+I W(J) = -A1+ELMBDA 110 CONTINUE GO TO (114,111,112,113,114,111),MBDCND 111 W(ID2) = A1 GO TO 114 112 W(ID2) = A1 113 W(ID3+1) = A1 114 CONTINUE C C ENTER BOUNDARY DATA FOR R-BOUNDARIES. C GO TO (115,115,117,117,119,119),MBDCND 115 A1 = W(1) DO 116 J=NSTART,NSTOP F(2,J) = F(2,J)-A1*F(1,J) 116 CONTINUE GO TO 119 117 A1 = 2.*DELTAR*W(1) DO 118 J=NSTART,NSTOP F(1,J) = F(1,J)+A1*BDA(J) 118 CONTINUE 119 GO TO (120,122,122,120,120,122),MBDCND 120 A1 = W(ID4) DO 121 J=NSTART,NSTOP F(M,J) = F(M,J)-A1*F(MP1,J) 121 CONTINUE GO TO 124 122 A1 = 2.*DELTAR*W(ID4) DO 123 J=NSTART,NSTOP F(MP1,J) = F(MP1,J)-A1*BDB(J) 123 CONTINUE C C ENTER BOUNDARY DATA FOR THETA-BOUNDARIES. C 124 A1 = 1./DLTHSQ L = ID5-MSTART+1 LP = ID6-MSTART+1 GO TO (134,125,125,127,127),NP 125 DO 126 I=MSTART,MSTOP J = I+LP F(I,2) = F(I,2)-A1*W(J)*F(I,1) 126 CONTINUE GO TO 129 127 A1 = 2./DELTHT DO 128 I=MSTART,MSTOP J = I+LP F(I,1) = F(I,1)+A1*W(J)*BDC(I) 128 CONTINUE 129 A1 = 1./DLTHSQ GO TO (134,130,132,132,130),NP 130 DO 131 I=MSTART,MSTOP J = I+LP F(I,N) = F(I,N)-A1*W(J)*F(I,NP1) 131 CONTINUE GO TO 134 132 A1 = 2./DELTHT DO 133 I=MSTART,MSTOP J = I+LP F(I,NP1) = F(I,NP1)-A1*W(J)*BDD(I) 133 CONTINUE 134 CONTINUE C C ADJUST RIGHT SIDE OF EQUATION FOR UNKNOWN AT POLE WHEN HAVE C DERIVATIVE SPECIFIED BOUNDARY CONDITIONS. C IF (MBDCND.GE.5 .AND. NBDCND.EQ.3) 1 F(1,1) = F(1,1)-(BDD(2)-BDC(2))*4./(FLOAT(N)*DELTHT*DLRSQ) C C ADJUST RIGHT SIDE OF SINGULAR PROBLEMS TO INSURE EXISTENCE OF A C SOLUTION. C PERTRB = 0. IF (ELMBDA) 144,136,135 135 IERROR = 11 GO TO 144 136 IF (NBDCND.NE.0 .AND. NBDCND.NE.3) GO TO 144 S2 = 0. GO TO (144,144,137,144,144,138),MBDCND 137 W(ID5+1) = .5*(W(ID5+2)-DLRBY2) S2 = .25*DELTAR 138 A2 = 2. IF (NBDCND .EQ. 0) A2 = 1. J = ID5+MUNK W(J) = .5*(W(J-1)+DLRBY2) S = 0. DO 140 I=MSTART,MSTOP S1 = 0. IJ = NSTART+1 K = NSTOP-1 DO 139 J=IJ,K S1 = S1+F(I,J) 139 CONTINUE J = I+L S = S+(A2*S1+F(I,NSTART)+F(I,NSTOP))*W(J) 140 CONTINUE S2 = FLOAT(M)*A+DELTAR*(FLOAT((M-1)*(M+1))*.5+.25)+S2 S1 = (2.+A2*FLOAT(NUNK-2))*S2 IF (MBDCND .EQ. 3) GO TO 141 S2 = FLOAT(N)*A2*DELTAR/8. S = S+F(1,1)*S2 S1 = S1+S2 141 CONTINUE PERTRB = S/S1 DO 143 I=MSTART,MSTOP DO 142 J=NSTART,NSTOP F(I,J) = F(I,J)-PERTRB 142 CONTINUE 143 CONTINUE 144 CONTINUE C C MULTIPLY I-TH EQUATION THROUGH BY (R(I)*DELTHT)**2. C DO 146 I=MSTART,MSTOP K = I-MSTART+1 J = I+LP A1 = DLTHSQ/W(J) W(K) = A1*W(K) J = ID2+K W(J) = A1*W(J) J = ID3+K W(J) = A1*W(J) DO 145 J=NSTART,NSTOP F(I,J) = A1*F(I,J) 145 CONTINUE 146 CONTINUE W(1) = 0. W(ID4) = 0. C C CALL GENBUN TO SOLVE THE SYSTEM OF EQUATIONS. C CALL GENBUN (NBDCND,NUNK,1,MUNK,W(1),W(ID2+1),W(ID3+1),IDIMF, 1 F(MSTART,NSTART),IERR1,W(ID4+1)) IWSTOR = W(ID4+1)+3.*FLOAT(MUNK) GO TO (157,157,157,157,148,147),MBDCND C C ADJUST THE SOLUTION AS NECESSARY FOR THE PROBLEMS WHERE A = 0. C 147 IF (ELMBDA .NE. 0.) GO TO 148 YPOLE = 0. GO TO 155 148 CONTINUE J = ID5+MUNK W(J) = W(ID2)/W(ID3) DO 149 IP=3,MUNK I = MUNK-IP+2 J = ID5+I LP = ID2+I K = ID3+I W(J) = W(I)/(W(LP)-W(K)*W(J+1)) 149 CONTINUE W(ID5+1) = -.5*DLTHSQ/(W(ID2+1)-W(ID3+1)*W(ID5+2)) DO 150 I=2,MUNK J = ID5+I W(J) = -W(J)*W(J-1) 150 CONTINUE S = 0. DO 151 J=NSTART,NSTOP S = S+F(2,J) 151 CONTINUE A2 = NUNK IF (NBDCND .EQ. 0) GO TO 152 S = S-.5*(F(2,NSTART)+F(2,NSTOP)) A2 = A2-1. 152 YPOLE = (.25*DLRSQ*F(1,1)-S/A2)/(W(ID5+1)-1.+ELMBDA*DLRSQ*.25) DO 154 I=MSTART,MSTOP K = L+I DO 153 J=NSTART,NSTOP F(I,J) = F(I,J)+YPOLE*W(K) 153 CONTINUE 154 CONTINUE 155 DO 156 J=1,NP1 F(1,J) = YPOLE 156 CONTINUE 157 CONTINUE IF (NBDCND .NE. 0) GO TO 159 DO 158 I=MSTART,MSTOP F(I,NP1) = F(I,1) 158 CONTINUE 159 CONTINUE W(1) = IWSTOR RETURN END |
tahnx for answering, but i can not refer the variables. that kind of programing language is it?
ax++ version 3.125
