-   -   k-eps in finite elements (http://www.cfd-online.com/Forums/main/3605-k-eps-finite-elements.html)
ben June 14, 2001 10:35
Hello, I'm looking for references on the implantation strategies of turbulence model (k-eps) in finite elements. Thanks for help ! Ben
Rayzoo June 14, 2001 18:34
welcome: k-eps
Where do you start from ?
clifford bradford June 14, 2001 19:18
Re: k-eps in finite elements
the code NSC2KE is a 2d NS code using k-e w/ finite elements. you can find a link to the code and documentation at http://capella.Colorado.EDU/~laney/softaero.htm
Rayzoo June 14, 2001 19:28
http://www.featflow.de ?
ben June 14, 2001 22:15
Re: welcome: k-eps
Hi, I know the finite elements : I work with a code for viscous steady and non-steady flows I know about k-eps, and I want to introduce it in my code. I'm looking for programation strategies, algorithm, practical know-how Thanks for help, Ben
Rayzoo June 16, 2001 11:11
Re: welcome: k-eps
Dear Ben,
I managed to program a 1D resolution (no simple algorithm) of the incompressible k-eps with finite differences for linearized custom equations with additionals sources. I was rather confident: I had yet solved analytical first order turbulence model (and spent weeks to relax it).
However, k-eps convergence appeared as a more relevant tricky business: my code still not converges. So, I wonder who can help you: programation strategies have been argued to depend on many conditions to me, herein. I could see various tricks within open sources codes, but these could not help me enough.
For finite elements, if read a preprint (Lee and Leone, 1991: "Numerical Modeling of Turbulent Dispersion Around Structures Using a Particle-in Cell Method", available as a pdf from the Lawrence Livermore National Lab.)
Paper refered to some 'clipping' method (used by the FIDAP code ? ), whose purpose is to avoid negative values for k and epsilon, and not too large nu_t values, but this is rather poorly documented, as are the various others tricks (e.g.: nu_t = C_mu*k^2/(tiny+abs(eps)), instead of: nu_t = C_mu*k^2/eps) involved within CFD solvers. I implemented clipping, as well as various unsuccessfulls relaxations schemes...
I planned to summarize tricks for k-eps, some day, so as more and more people can develop open source codes, within buying some more book. If you plan to go this way, please, do not embed pre- and post processing, it would be easier to understand. You may find links to postprocessing software within the forum.
For pre-, post-, as well as 'proto' processing purposes, high level interpreted languages toolboxes (e.g.: Scilab may incorporate finite elements utilities) may help, at computing time cost, however. For research purposes this shouldn't hurt (much).
Own opinion(heard this as open source developpers policy): consider starting from an existing software provided by some of the links below. This way, you may spare pain re-using a maximum of availables (if suited enough) parts.
Hope some Doctor will let us know more
