transient flow
Old   June 19, 2001, 17:22
Default transient flow
Newbie
Hi, I would like to ask to all you CFD guys about information dealing with transition flow modeling using CFD.
Articles, books, software, web pages and any other source are more than wellcome.
I haven't found much so far.
Thanks a lot
Newbie
Old   June 19, 2001, 18:11
Default Re: transient flow
Alton J. Reich
Are you asking about transient (i.e.: time dependent) flow, or transition (i.e.: laminar to turbulent) flow?
They are very different things and those differences are very important.
Regards, Alton
Old   June 19, 2001, 22:10
Newbie
You're right Alton, its the transition from laminar to turbulent in which I'm interesting. Thanks Newbie
Old   June 20, 2001, 00:54
John C. Chien
(1). In the standard book by Schlichting, "boundary Layer Theory",it has two chapters on the transition, The origin of turbulence I and II. (2). It should give you the needed information. It is a very difficult field. (3). On the two-equation turbulence modeling side, low Reynolds number models have been used to capture the laminar, transitional and turbulent flow. (4). You can check the ASME/Journal of turbomachinery for papers on the turbine blade heat transfer cfd analysis. In this area, one must consider laminar, transitional and turbulent boundary layer for proper prediction of blade heat transfer.
Old   June 20, 2001, 01:37
S.Hjort
The textbook indicated by John is classic and a logical starting point. For comprehensive introductions into more recent development in transition modelling try the AGARD publications R-709 ("Special Course on Stability and Transition of Laminar Flow" 1984) and R-793 ("Progress in Transition Modelling" 1994)
Regards Soren
Old   June 21, 2001, 11:56
newbie
Thanks to John and Sorensen,
Regards
Newbie
Problem with transient solution of flow past a row of cylinders jostanek Main CFD Forum 0 January 6, 2010 12:16
TRANSIENT ANALYSIS OF JET FLOW shriramjegan FLUENT 0 July 28, 2007 12:04
transient compressible flow simulation-urgent JSM FLUENT 0 April 26, 2007 01:51
transient compressible flow problem (urgent plz) jehanzeb FLUENT 5 August 3, 2004 08:04
PhD in turbulence Hans Main CFD Forum 14 October 8, 2001 03:03
