RDT for turbulent flow
Old   June 22, 2001, 11:03
Default RDT for turbulent flow
mnasri chokri
I seek for help about rapid distorsion theory, specially, i would like to know if there is any real turbulent flow that RDT gives good approximation. thanks in advance.
Old   June 22, 2001, 12:02
Default Re: RDT for turbulent flow
kalyan
As you may already know, RDT is mostly a linear theory which predicts the effect of rapid strain rates on turbulence. The time scale associated with the strain rate induced distortion is assumed to be much smaller than the inertial time scales (i.e., time scale associated with modal interactions).
Turbulent flow across a shock wave (I am guessing) fits the bill perfectly. If the transit time across the flame is much smaller than the turbulence time scales, flow across a turbulent flame (actually flame brush in turbulent flows) also can perhaps be studied using RDT.
Thread Tools
Trackbacks are On
Flow meter Design CD adapco Group Marketing CD-adapco 3 June 21, 2011 08:33
Can OpenFOAM generate flow at the speed of light? Michel_sharp OpenFOAM 6 October 24, 2009 04:09
mass flow in is not equal to mass flow out saii CFX 2 September 18, 2009 08:07
What is the difference between liquid reactive flow and gas reactive flow? James Main CFD Forum 6 May 15, 2009 12:14
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
