Turbulence Models.
Old   June 27, 2001, 07:17
Default Turbulence Models.
Gavin Brady
I have been asked to use a "Realizable k-eplsilon" model in my industrial project for my masters. Does anyone know what is the fundamental difference between this and the standard "k-eplsilon" model? All comments appreciated. Cheers.
Old   June 27, 2001, 07:55
Default Re: Turbulence Models.
sylvain
The name Realizable k-epsilon model is used by Fluent for the Shih, Zhu and Lumley evolution of the k-epsilon model. It refers to several NASA/ICOMP papers. The final and "really" realizable version of this model is describe in the following paper "Developments in Computational Modeling of the Turbulent Flows" - Tsan-Hsing Shih - NASA Contractor Report 198458 - ICOMP-96-04; CMOTT-96-03 - February 1996.
The main features of this model are the following :
- uu = 2/3*k - 2*c_nu*k^2/eps*dU/dx can NOT be negative since c_nu is no more a constant.
- the production term of the epsilon equation is equal to c_1*eps*S instead of c_eps_1*c_nu*k*S^2, where c_1 is NOT a constant.
This last item gives a better stability to the turbulence model.
Hope that helps,
Sylvain
Old   July 14, 2001, 02:27
Max
simply speaking, realizable k-e models impose some conditions, usually derived based on some turbulence physics arguments, to prevent k and e (or some parameters derived from k and e) from going to wrong values...
Thread Tools
Trackbacks are On
Turbulence postprocessing Mohsin FLUENT 0 September 19, 2011 21:05
Incompressible Turbulence models achinta OpenFOAM 4 May 27, 2010 10:35
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
How to set phase dependent turbulence models? J.Yang CFX 2 August 29, 2002 15:39
