[Sponsors] | |||||
Hi
In the horizontal momemtum equation written in this form Dt(v) + div(Vv) + Dz(Vw) + f(k X v) + grad p = Q where Dt(v) is partial differential of momemtum density w.r.t time t , grad p is the pressure gradient, Q is source/sink due to mass/force ,f is the Coriolis parameter and v = V/rho is the momemtum density, what does div(Vv) stand for? Why should that term be there? Thanks a bunch |
Hi
The term div(Vv) is link to lagrangian derivation (i.e. derivation along streamlines). From a formal point of view, the momentum equation comes from a conservation equation with an integral form (Newton principle): d_t{INT_omega(t)[rho U]dV}=INT_omega(t)[volume forces]dV+INT_sigma(t)[surface forces]dS (1) where INT means integration, omega(t) is a volume varying with time and sigma(t) the boundary of this volume. Because omega is time depending, you cannot permute d_t and INT_omega(t) directly. The correct way to do this is to use the following formulation d_t{INT_omega(t)[A]dV}=INT_omega(t)[d_t(A)]dV+INT_sigma(t)[A*U]dS, where A is a vector and * is a tensorial product The equation (1) then becomes : INT_omega(t)[d_t(rho U)]dV+INT_sigma(t)[rho]dS =INT_omega(t)[volume forces]dV+INT_sigma(t)[surface forces]dS Using Green's theorem ( INT_sigma[A]dS =INT_omega[DIV(A)]dV with DIV the divergence of a tensor) we can write: INT_sigma{ d_t(rho U)+DIV((rho U)*U)}dV= INT_sigma{ Volume force + DIV(Surface forces)}dV Now we assume that the fluid is newtonian with viscosity equal to 0, that the density rho is constant (incompressible) and that we're in a rotating frame. Then, suppressing the INT_, the equation (vector formulation) writes : d_t(U)+DIV((rho U)*U)=-grad(p)/rho + Coriolis + additionnal volume forces + div(additional surface forces) Projecting this along an axis (X for instance), we obtain (div is the divergence of a vector): d_t(u)+div(uU)=d_t(u)+d_x(u^2)+d_y(uv)+d_z(uw)= -d_x(p)/rho + (...).X, where u,v,w are the three components of the velocity vector U. Best regards |
Dear Number
This term correspond to the transfer of momentum by convective motion inside the fluid. This term should be there only if you want to write the real Navier-Stokes eq. or if it is comparable (in order of magnitude) to the rest of the term into the equation. As you can see this is a non-linear term and it is maybe one of the more important reasons (personal opinion) why we are here in this forum talking about COMPUTATIONAL Fluid Dynamics. Regards Kike |
You can check the book of Prof. Slattery: Momentum, Energy, and Mass Transfer in Continua. This is a result of transport theorem for a region containing a singular surcafe.
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Guide: Writing Equations in LaTeX on the CFD Online Forums | pete | Site Help, Feedback & Discussions | 8 | May 2, 2013 22:15 |
| Favre averaged Navier-Stokes equations help | siw | Main CFD Forum | 2 | April 20, 2012 06:45 |
| CFD governing equations | m.gos | Main CFD Forum | 0 | April 30, 2011 14:21 |
| solving only turbulence equations | afroz_javed | OpenFOAM | 1 | January 20, 2011 05:25 |
| Question about UDS equations | tstorm | FLUENT | 1 | January 11, 2010 13:02 |
