June 27, 2001, 07:17 |
Turbulence Models.
I have been asked to use a "Realizable k-eplsilon" model in my industrial project for my masters. Does anyone know what is the fundamental difference between this and the standard "k-eplsilon" model? All comments appreciated. Cheers.
June 27, 2001, 07:55 |
Re: Turbulence Models.
The name Realizable k-epsilon model is used by Fluent for the Shih, Zhu and Lumley evolution of the k-epsilon model. It refers to several NASA/ICOMP papers. The final and "really" realizable version of this model is describe in the following paper "Developments in Computational Modeling of the Turbulent Flows" - Tsan-Hsing Shih - NASA Contractor Report 198458 - ICOMP-96-04; CMOTT-96-03 - February 1996. The main features of this model are the following : - uu = 2/3*k - 2*c_nu*k^2/eps*dU/dx can NOT be negative since c_nu is no more a constant. - the production term of the epsilon equation is equal to c_1*eps*S instead of c_eps_1*c_nu*k*S^2, where c_1 is NOT a constant. This last item gives a better stability to the turbulence model. Hope that helps, Sylvain |
July 14, 2001, 02:27 |
simply speaking, realizable k-e models impose some conditions, usually derived based on some turbulence physics arguments, to prevent k and e (or some parameters derived from k and e) from going to wrong values...
Turbulence postprocessing | Mohsin | FLUENT | 2 | October 3, 2016 14:18 |
Incompressible Turbulence models | achinta | OpenFOAM | 4 | May 27, 2010 10:35 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
How to set phase dependent turbulence models? | J.Yang | CFX | 2 | August 29, 2002 15:39 |
