June 6, 2001, 02:56 |
pipe flow calculations
basically i am interrested to calculate the velocity field in entrance rigion of a pipe with the use of Navier stokes equn. how to discretise the euqn. in cilyndrical co-ord. system
June 6, 2001, 03:11 |
Re: pipe flow calculations
(1). In this particular case, I would suggest that you transform the governing equations into the classical stream function-vorticity equation formulation. (2). You should be able to find the finite-difference formulation in most cfd books related to the solutions of the stream function equation and the vorticity equation. (3). You can use the second order central difference for the stream function. For the vorticity transport equation, you can use the central difference for the diffusion term, and the upwind difference (or higher-order method) for the convection term. (4). With a non-uniform Cartesian mesh, you should be able get the solution quite easily. (5). For turbulent flow, you will have to solve the turbulence model equations.
June 6, 2001, 03:37 |
no ,i am interested to solve the problem by primitive variable methods.hoe could i do it ap tp=as ts+an tn+aw tw+ ae te.where t is a property.how to find ap,as,an,aw,ae by discretising the p.d.e in cylindrical coordinate system
June 6, 2001, 03:52 |
(1). Don't tell me that you are going to use staggered grid. (2). For example, dT/dx~ (T(i+1,j)-T(i-1,j))/deltaX/2., d(dT/dx)/dx~ (T(i+1,j)-2T(i,j)+T(i-1,j))/(deltaX*deltaX),...etc. (3). Repeat this for dT/dy, d(dT/dy)/dy,... in the same way. (4). Now you have the finite-difference equation written in terms of T(i+1,j), T(i,j), T(i-1,j), T(i,j+1), T(i,j-1). (5). If you collect all of these terms, you will get something like AE*T(i+1,j), AW*T(i-1,j), AN*T(i,j+1), AS*T(i,j-1), and (AE+AW+AN+AS)*T(i,j),...etc. Here you can call (AE+AW+AN+AS)=AP. (6). Naturally, you will have additional coefficients in front of the differential terms.
June 6, 2001, 05:20 |
yes , i am using staggered grid system. ok.it is all ok for catesian co-ordinate sytem, but i want the values of the co-efficinet for the cylindrical co-ordinate system
June 6, 2001, 12:03 |
(1). I don't use that method in staggered grid, so you will have to get someone else to help you for the cylindrical coordinates formulation.
June 7, 2001, 00:59 |
whom should i contact or any book???
July 7, 2001, 12:01 |
hello there .i am a final year mechanical engg student. i am interested in doing my MS degree in cfd.i do not have any idea about the scope or future of this subject.i just have an idea abou the beauty of the subject.please advice me at prakashbayadi@yahoo.co.in .i am sorry for writing such a letter whilst you might be expecting a technical one.please reply.thanking you,
Ramaprakash B |
High speed compressible flow through pipe | Munni | Main CFD Forum | 6 | December 7, 2015 11:33 |
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) | florian_krause | OpenFOAM | 22 | June 13, 2013 21:25 |
Pipe Flow | Saima | CFX | 1 | January 10, 2011 16:41 |
Turbulence in a pipe flow | JM | Main CFD Forum | 4 | December 21, 2006 04:04 |
flow in pipe with momentum and energy source | Atit Koonsrisuk | CFX | 3 | March 29, 2005 16:58 |
