To verify case study
Old   July 15, 2001, 02:19
Default To verify case study
ruengsak panyasen
Hello..
I am new for this field.I want some advise for my case study.Now i am testing my source code dealing with ventilation system in the space on the base of turburent flow,steady state.
Best regard.
Ruengsak.
Old   July 15, 2001, 15:44
Default Re: To verify case study
John C. Chien
(1). You can always run some simple test cases where the test data or solutions are known. (2). For the specific configuration, you will have to run some tests to get your results validated, depending on your goal and interest of the calculation or simulation.
use batch mode to run an unsteady case PaulineP FLUENT 9 April 4, 2019 08:18
[snappyHexMesh] Editing the motorBike case, loading diffirent .stl btgyd OpenFOAM Meshing & Mesh Conversion 1 September 26, 2011 17:24
Centrifugal Fan Case Study Results Required using CFX kambireddy CFX 0 October 8, 2010 05:46
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
Aero study for symmetry case Nevur FLUENT 2 September 28, 2005 01:38
