-   -   CFD Package for Water Pump Design !!! (http://www.cfd-online.com/Forums/main/3748-cfd-package-water-pump-design.html)
John Sheng July 31, 2001 13:47
Which CFD package is the best for analyzing the water pump, such as centrifugal pump, radial pump, etc. Thanks a lot for your kind comments in advance.
John sheng
John C. Chien July 31, 2001 14:05
Re: CFD Package for Water Pump Design !!!
(1). The code can not do analysis by itself yet. (2). So, you need to look for the best person who has experience in water pump analysis. (3). I had done some, but I don't think I am good at it.
John Sheng July 31, 2001 16:23
Hi, Mr. Chien, Thank you very much for your kind response. You are definitely right. FLUENT can do water pump analysis. However, I would like to know if there is any other commercial CFD software specially good for modelling the water pump. Anybody has experience in water pump analysis, please give me your advice. Thanks.
John C. Chien July 31, 2001 19:38
(1). You probably need more than one software package,because you will need the geometry part,the mesh generation part, the solver part. (2). There are several packages available in these areas. (3). Why not visit the websites of forum sponsors first. You should be able to find some useful packages suitable for your applications. Make sure that you take a look at (a). geometry part, (b). mesh generation part, (c). solver part. (which must be compatible with geometry and mesh) (4). Some users like the accurate solution, and some users love the easy mesh generation. So, it is important to evaluate these requirement in selecting the software, if you have to use the commercial codes.
Herve August 1, 2001 03:29
For rotary pump, CFX-TascFlow is well represented in industry.
A.S. August 1, 2001 04:32
CFX Tascflow is the best available commercial software for pumps and turbo machines. The other choice can be Numeca software but as far as my knowledge goes it is more suitable for Turbo Machines. You can contact their respective offices regarding your problem.
Regards
ICEM UK August 1, 2001 08:37
As the others say, CFX TASC flow is the ideal solution
Remy Tasse September 4, 2001 09:29
NUMECA offers very efficient CFD package for pump design and analysis. The tool FINE/Turbo is dedicated for 3D flow analysis and FINE/Design3D id dedicated for 3D optimization using CFD, genetic algorithms and neuronal database. I suggest to call NUMECA in order to get more information.
