August 3, 2001, 05:26 |
S-Shaped circular duct!
HI,
Any body has the paper titled : An experimental Investigation of Secondary flows in a S-Shaped circular ducts. Author : Vakili. A. Or else, If any body has solved this bench mark problem earlier, can you please pass over the inlet total pressure, total temperature and outlet static pressure. Thanks, Ravi. |
August 3, 2001, 06:23 |
Re: S-Shaped circular duct!
I am not sure but I think that this benchmark can be found either in Nparc or Ercoftac validations cases.
Take a look a resources/validation section. Sincerely |
August 3, 2001, 11:02 |
The problem was solved as a demo by
P. He, M. Salcudean, I. S. Gartshore and P. Nowak, "Multigrid Calculation of Fluid Flows in Complex 3D Geometries Using Curvilinear Grids," Computers & Fluids, Vol 25, #4, pp. 395-419, 1996. |
August 9, 2001, 19:44 |
where can I find these?
August 10, 2001, 04:28 |
you can find an S duct example at the NPARC validation server.
The address is http://www.grc.nasa.gov/www/wind/valid/sduct/sduct.html |
August 15, 2001, 10:32 |
I used Pepsi(developed by NASA Lewis) to design boeing 727 s duct and validate with full scale ground test data. You can see the results in my AIAA paper around 1992.
S shaped duct | francois | Main CFD Forum | 5 | May 16, 2014 05:44 |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
2D simulation of circular and rectangular duct | mvee | FLUENT | 4 | March 23, 2007 23:40 |
modelling fuel cell duct in fluent | rajesh kumar tippabhotla | FLUENT | 2 | October 7, 2004 12:04 |
flow simulation across a small fan | jane luo | Main CFD Forum | 15 | April 12, 2004 17:49 |
