Help With Modeling A Projectile Fluid In Flight.
Old   December 10, 1998, 21:24
Default Help With Modeling A Projectile Fluid In Flight.
Dzeff G.
I am a student of chemical engineering at the university of Connecticut in my junior year. I am trying to model a fluid that is sprayed out of a spray bottle. The experiment is to prove that viscocity and surface tension have some proportionality to the spread of radius of these fluids at different distances away from the nozzle. Three different fluids were used- Water, Vegetable oil, and Acetone. We added food coloring to the fluids and sprayed them through a white mesh fabric. We were then able to measure the radius of the perfect circular print left behind. As expected, the more viscus the fluid was, the less the radius changed. Now my question is - HOW DO YOU MODEL THAT? I assume that the fluid breaks apart when the force of drag acting opposite the directrion of flow becomes greater that the force of surface tension and/or viscocity. I also assumed that the fluid was a continuum and that the fact that the fluid broke up into droplets was negligable. Please help with any suggestions. Feel free to post your response here or e-mail me @ jjg98001@uconnvm.uconn.edu. Thank you
Dzeff...
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
modeling movement of body in fluid Hossein FLUENT 0 November 18, 2008 04:33
Fluid Dynamics Eng - PAX Mixer - San Rafael, CA Gary Jong FLUENT 0 February 25, 2008 20:46
Fluid domain creation for jet fan modeling hari FLUENT 0 November 7, 2007 01:25
fluid structure interaction taru agrawal FLUENT 4 September 10, 2007 03:12
