zero flux bc's on FDM 9-noded patch
Old   August 14, 2001, 12:35
Default zero flux bc's on FDM 9-noded patch
E Siebrits
Given equation:
d/dx(X1*du/dx + X2*du/dy) + d/dy(Y2*du/dx + Y1*du/dy) = ...
where X1, Y1, etc are constants.
2nd-order FDM discretization of this equation system on a regular mesh (with rectangular elements) yields a 9-noded molecule in variable 'u' with the usual W, E, S, N, and C (center) coeffs, but also NW, NE, SW, and SE.
My question is how to correctly apply a zero flux bc, especially when acute or obtuse corners are present on the mesh boundaries of an irregular-shaped 2D domain?
Any pointers will be welcome!
Thanks
Old   August 14, 2001, 14:37
Default Re: zero flux bc's on FDM 9-noded patch
John C. Chien
(1). Through the coordinate transformation of the original equations and the boundary conditions.
Old   August 14, 2001, 21:09
joe
your answer is like this ...
A : How can I cook chinese food ?
B : Through your hand.
Old   August 15, 2001, 00:07
John C. Chien
(1). I guess there is the missing part. That is the mesh. (2). By using the coordinate transformation, you will have the governing equation written in the general coordinates, which is yet unknown. (3). But if you then create a mesh which is normal to the boundary, then the zero flux boundary condition is just: t(Xi_at wall, Eta, Zeta)= t(Xi_at wall - 1, Eta, Zeta), if Xi is the coordinate normal to the local wall. (4). If you are serious about the zero flux condition, then the numerical grid generation is a good one to try. (5). By the way, I normally by-pass the cooking step, and buy the Chinese food (cooked) at the local mall's PANDA EXPRESS fast food place. (6). So, zero flux means the normal gradient is zero, that is you need to define the local wall point and a point on the line normal to the wall point. That means a local mesh line must be normal to the wall. When you have this local behavior of the mesh, the zero flux condition is very simple.
Old   August 15, 2001, 00:19
John C. Chien
(1). If on the other hand, you insist on using the regular coordinates (Cartesian or the like), then you can find a point of the mesh near the wall first, then draw a normal to the wall, find the wall point, then assign the value on the wall equal to the near the wall point. (2). After you have these wall point values updated, then use interpolation to compute the values at other wall points if needed.
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
