massflow outlet boundary condition ??
Old   August 17, 2001, 06:46
Default massflow outlet boundary condition ??
Charles Renard
hi !
i am wondering how to model a fresh air entry on a vehicle.(i am currently working on external aerodynamics) i already modeled the corresponding hot gases oulet with a mass flow inlet boundary condition.
my issue is that i only know the mass flow rate (the same as for hot gases outlet), and it seems that fluent 5 has no "outlet massflow" boundary condition.
Help needed !
thanks Charles
Old   August 17, 2001, 09:17
Default Re: massflow outlet boundary condition ??
Sebastien Perron
For outflow, isn't a free exit BC ?
If it is, then you don't need any outlet massflow BC.
Old   August 17, 2001, 09:19
chiseung
I'm afraid that I understood your question exactly. As I understood, you only know the mass flow rate at outflow in your system.
If so, give the mass-flow-inlet b.c. to your outflow boundary and assign a negative value. That means mass is flowing out of your system at constant rate.
Old   August 17, 2001, 10:30
Charles Renard
hi !
i cannot do that because the flow is just a small part (a sort of cooling inlet/oultet) of a bigger flow around a vehicle.
i tried to input a negative value for massflow inlet but fluent does not accept it.
i think i will have to use UDF to declare a constant velocity pointing outwards the flow domain around the vehicle.
any other suggestion is welcome...
Charles
Old   August 17, 2001, 12:08
Charles Renard
i just tried to put a negative value in inlet-velocity; fluent accept it and results don't seem too bad at first glance...
has someone already used this "not-so-pretty-method" ?
thanks
charles
Old   August 18, 2001, 07:55
J. Keays
Yes, I have used a negative value for velocity at the exit to obtain a velocity out of the system. It works very well. I don't think there is much of a problem with it, particularily if the boundary layer is unimportant.
J.
Old   August 20, 2001, 04:27
Charles Renard
ok
so i guess i will use this method too. i tried to draw pathlines released from the area and i got nothing going inside my flow domain, so yes i guess lines are "going outside".
thanks Charles
Outlet Boundary Condition ashtonJ CFX 6 April 26, 2011 09:09
CFX Solver : Sudden crash Hervé CFX 2 June 16, 2008 07:40
Help needed for outlet boundary condition YY CFX 7 April 20, 2008 23:04
Outlet boundary condition CN FLUENT 6 May 22, 2005 10:37
Outlet velocity boundary condition Jay FLUENT 4 December 15, 2002 09:27
