September 28, 2009, 14:52 |
Coanda effect
Rep Power: 16 |
hi
Could somebody give me some explanation about coanda effects. I searched internet, it seems that due to the entrainment between wall and ambient fluids, the flow will move fast close to the wall. According to Bernoulli principles, it will produce a lower pressure and then bent the streamlines. However I have several questions? 1) what is the effects of viscousity? 2) what is the effects of surface friction? if there is no surface friction, does still coanda effect occur? 3) what is the effects of flow separation on the wall? 4) what is the relationship between coanda effects and surface tension. Thanks a lot |
September 29, 2009, 10:19 |
Rep Power: 16 |
Could somebody give me some hints. Thanks a lot....
September 29, 2009, 21:01 |
Rep Power: 16 |
could somebody please help me with these quesitons? Thanks a lot
September 29, 2009, 21:55 |
Radiatn
Rep Power: 17 |
A: The higher the viscosity, the higher coanda effect 2) what is the effects of surface friction? if there is no surface friction, does still coanda effect occur? A: Yes, still occur even if not surface friction, but in reality there is always surface friction i.e. law of the wall, y+ 3) what is the effects of flow separation on the wall? A: If there is separation, the flow of the coanda is disturbed 4) what is the relationship between coanda effects and surface tension. A: The higher surface tension, the bigger coanda effect Regards! But the answers should be your area of study, there is no quick simple answer in reality. |
September 30, 2009, 09:53 |
Rep Power: 16 |
Thanks radiatn.
However, I still do not quite understand. It seems that the coanda effect is due to the Bernoulli effects which basically is inviscid effect. How does the viscoucity connect to this effect? What is the meaning of stronger coanda effects(what kind of quantities can be used to quantify the coanda effects, since the flow deflexion angle is always determined by the inclination angle of the walls(always parallel to the wall). If I put a needle into to tape water, the water will follow the needle. Is this coanda effects? Since there is no much entrainment occurring for this case, it seems a purly surface tension effects. Can I also call this type phenomena coanda effects? Thanks a lot... |
October 11, 2009, 09:34 |
Coanda effect at the particle level
Charles Crummer
Rep Power: 16 |
In http://arxiv.org/abs/nlin/0507032 I have tried to explain the cause of the Coanda effect. CFD is the study of the computation of the behavior of fluids. It is not necessarily the study of the causes of the behavior. The fluid approximation is primary in CFD. I think, however, that the explanation of the Coanda effect requires that one thinks of a fluid, correctly, as being made up of particles. To use a macroscopic term, shear in the fluid near a convex surface is the cause of the Coanda effect. The Bernoulli effect and the Coanda effect are quite different. Please let me know what you think.
October 11, 2009, 12:59 |
#7 | |
Ahmed
Rep Power: 18 |
Thanks for the reference, worth reading, truly. .................................................. ................ Open Source for ever .................................................. .................................................. ....... |
October 12, 2009, 07:17 |
Charles Crummer
Rep Power: 16 |
I'm interested in knowing more about your project. How was the Coanda effect used?
October 13, 2009, 06:08 |
Coanda and Bernoulli
#9 |
Charles Crummer
Rep Power: 16 |
To nacaairfoil,
In http://arxiv.org/abs/nlin/0507032 I try to explain the difference between the Bernoulli and the Coanda effects. The Bernoulli equation uses the principle of the conservation of energy to relate changes in altitude, pressure and velocity in the flow. It does not address the way in which the fluid interacts with itself and with the walls of the Bernoulli tube to produce these effects. The Coanda effect, on the other hand, can only be explained by the interactions between the fluid and itself and the surface. Viscosity is a macroscopic notion that is meant to reflect in a very general way these interactions. Of late, CFD researchers have introduced a complex viscoelastisity to explain some of these phonemena and at the same time maintain the fluid approximation. I think this approach amounts to putting mathematics and computation before the physics. We need a whole new computational approach. |
October 22, 2009, 15:42 |
#10 |
Charles Crummer
Rep Power: 16 |
To nacaairfoil.:
1) what is the effects of viscousity? Viscosity is a measure of the interaction of the fluid with a surface. This interaction could be very complicated and turbulent. 2) what is the effects of surface friction? if there is no surface friction, does still coanda effect occur? I assume you mean surface roughness, e.g. the roughness of a wing. Since all materials have a granular structure, they are made of molecules and atoms, there is always surface friction. The Coanda effect is caused by the interaction of molecules in the main flow with more or less stagnant molecules in the boundary layer. 3) what is the effects of flow separation on the wall? Flow separation occurs when the pressure in the boundary layer pressure builds up. This rise in pressure is reflected in a complex and turbulent boundary layer. Can you send a drawing? 4) what is the relationship between coanda effects and surface tension. In a liquid, surface tension is caused by the attractive intermolecular van der Waals forces. In air or any other gas these forces are negligible since the molecules are in each others' near vicinity for such a short time. The phenomenon of a stream of water clinging to a spoon is due to the van der Waals forces. The Coanda effect in air has a very different cause. The shearing air flowing along a convex surface is attracted to the surface. When the wing is working properly, i.e. not stalled, the low pressure on its front top surface is maintained. |
October 22, 2009, 18:33 |
#11 |
Rep Power: 16 |
Hi Charlyandy
I am very insterested in your paper and work, just did not have time to fish the reading. My project is involved in airflow during phonation. During phonation, the flow is a very asymmetric inside the glottis. A lot of people think that is due to the coanda effects. I am trying to find the real cause for this type flow asymmetry. That's why I am looking at what is exactly cause behind this coanda effects. Again thanks a lot for your posting. I might have some question to ask you after reading your paper. |
October 23, 2009, 07:11 |
Coanda effect in phonation
#12 |
Charles Crummer
Rep Power: 16 |
To: nacaairfoil,
Since the throat forms a sort of Bernoulli tube, I suspect that the overall pressure and velocity there are predicted by Bernoulli's equation. However it would seem that localized pressures very near the surfaces, e.g. the glottis, will fluctuate according to the curvatures that are created by the muscles in the throat. I am really intrigued by this. Maybe in phonation, and other activities like Tuva singing, we make use of the Coanda effect. I was listening to the call of the Lyre bird yesterday. Incredible! |
Coanda ejectors | Rajesh | FLUENT | 5 | December 12, 2010 10:02 |
simulating coanda effect | alfin | FLUENT | 6 | January 8, 2007 11:11 |
Coanda - once again | Bo Jensen | Main CFD Forum | 3 | January 24, 2006 20:23 |
Iclude particle diameter effect in wall? | yueroo | FLUENT | 0 | April 14, 2001 03:56 |
coanda effect | Craig Robbins | Main CFD Forum | 5 | September 8, 1998 23:21 |
