Help with liquid-liquid multiphase litterature |
August 20, 2001, 07:07 |
I am a graduate student, and I would like to ask for tips on good litterature (books or articles) covering the problem of modelling flow of two or more liquids that flow in separate layers (for example the VOF model). I would like an overwiev of the problem and descriptions of the different methods rather than just applications where the models are used. If you know of some good litterature on the subject, please let me know! If there are any litterature available online it would be even better. Thanks.
August 20, 2001, 12:08 |
Re: Help with liquid-liquid multiphase litterature
Have a look to this:
Two-phase flow: Models and Methods. Stewart, H and Wendroff, B J. Comp. Phys. 56, 363 (1984) good look dia |
August 20, 2001, 13:17 |
Try
http://t3.lanl.gov/gabe/secondlevel/codes/ripple.htm This is the documentation for the ripple code, which uses VOF with a bunch of new ideas. These guys are usually very thorough in building the backround for their methods. Good luck! |
August 20, 2001, 15:16 |
Mix Me
Start by using the search in the main forum. You will find alot of discussions and links...
I can give you good articles about each method, however I'm not too familiar with one that compares all of them. Its easier if you state your application, then the method of choice is usually easy to pick... If you want papers to read on-line try: Zaleski's homepage VOF Sussman's homepage LevelSet Trygvasson's homepage Tracking Gosman's homepage High Resolution The links are easy to find just search for them... Search also the Journal of Computational Physics, you will find alot of articles on the subject there. |
Multiphase flow (Comp. jet of gas into liquid) | Sarah | FLUENT | 1 | October 7, 2013 21:39 |
Multiphase flow and convergence issues | Erik | FLUENT | 1 | July 13, 2009 17:08 |
multiphase liquid vapour | Habbash | FLUENT | 0 | June 13, 2009 19:06 |
radiation of molton liquid metal in enclosure | richard | CFX | 0 | April 8, 2008 15:43 |
Multiphase modeling using liquid oxygen | Erik | FLUENT | 1 | December 6, 2007 08:51 |
