flow past sphere: surface pressure distribution
Old   August 17, 2001, 17:45
Default flow past sphere: surface pressure distribution
roland schmehl
hallo, can anyone refer me to computed (or measured) pressure distributions at higher Reynolds numbers, say Re > 500. background: i need the time averaged pressure as a boundary condition for a linearized droplet deformation model. thanks a lot - roland
Old   August 21, 2001, 08:20
Default Re: flow past sphere: surface pressure distributio
Axel Rohde
Have you looked in Hermann Schlichting's book "Boundary Layer Theory" yet? You ought to be able to find something there that suits you. Tons of stuff on spheres, plus many references.
Old   August 21, 2001, 12:54
roland schmehl
axel, thanks for the hint. i checked the 7th edition (1979) where the only thing i could find was an experimental pressure distribution from o. flachsbart (1932) at high subcritical Re. so, i guess you are refering to a newer edition of this book? anyway, i will definitely try that. roland
Old   August 21, 2001, 13:29
Axel Rohde
Roland:
Yes, I also have the 1979 seventh (English) edition, republished by McGraw-Hill in 1987. The references of Chapter 1 (p.23 in my book) include several papers on spheres. My personal favorite is {1] Achenbach.
You can adjust the Cp of any subsonic compressible result via the Prandtl-Glauert Rule to get incompressible Cp.
If you speak German (your name sounds like it) you can even read the German originals. There are quite a few!
Axel
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
back pressure at exit for supersonic flow BigFrank FLUENT 6 April 24, 2014 15:13
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
pressure distribution of potential flow karthik FLUENT 0 July 7, 2005 06:14
viscous free surface flow past a ship hull lololo Main CFD Forum 0 June 12, 2002 23:02
