-   Main CFD Forum (
-   -   Preconditioner (
Nailya August 29, 2001 03:12
Hi, I'm Nailya. I solve Navier-Stokes equations in implicit way using finite difference method on unstructured meshes, TVD method, Newton's method. The obtained linearized system I try to solve using GMRES method. The problem is that the matrix of system is very ill-conditioned. I need in a good preconditioner. How can I obtain it?
David Sun August 31, 2001 15:47
Re: Preconditioner
You can try to find some packages such as QMRPACK, SPARKSKIT from netlib and there are some preconditioning GMRES built in...
Chuck Leakeas August 31, 2001 17:58
Re: Preconditioner
Nailya, Why is your system of equations so ill-conditioned? Make sure you assemble your matrix correctly. You can start trying to precondition your system of equations using a Jacobi Preconditioner.
