-   Main CFD Forum (
-   -   on cavity driven flow (
yfyap September 18, 2001 22:13
hi there,
i have coded a progrom to simulate the flow in a rectangular cavity. the problem is formulated in vorticity-stream function. i employed the method of false transient and solutions were obtained for various Re numbers. to my surprise, for Re>100(upwind scheme is used for Re>100), i obtained two different solutions for each Re by using different time step. i checked for the continuity equation and it is satisfied for both solutions.
can this be true or is it a kind of bifurcations? please advise. thanks in advance.
regards, yfyap
Junseok Kim September 19, 2001 06:24
Re: on cavity driven flow
One of possibility is upwind method is explicit scheme, so it has CFL condition which is restricted by Re number.
Sebastien Perron September 19, 2001 08:12
Sorry, there is only one solution for each Re nunber. Was your system truly converged in both cases?
John C. Chien September 19, 2001 18:16
(1). Check out your code on a simpler check case first. (2). What is your "false transient" method?
