gas flow thougth water
Old   October 11, 2001, 09:06
Default gas flow thougth water
Roued
How do I model using CFD the flow of gas thought a water tank and away from the surface ?
Would a multi-phase approch or Lagrangian particle tracking with models for Particle evaporation/ablation with latent heat exchange.
The gas comes under high pressure, the pipes breaks and gas is leaking out into the water and is colded of due to sudden pressure drop, but continue to flow though the water until the free surface and further away from there.
Thanks for any hints !
Regards
Roued
Old   October 11, 2001, 10:50
Default Re: gas flow thougth water
Jon
This will depend on the volume fraction of the gas in the water. If its large, then you will have to use Eulerian. Anything above 5-10% will need Eulerian.
Otherwise use Lagrangian
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 06:44
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
Liquid water, gaseous water and another gas Andy FLUENT 1 May 22, 2006 09:51
question about ideal gas thermal flow yong Main CFD Forum 0 January 7, 2006 00:58
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
