-   -   turbulence (http://www.cfd-online.com/Forums/main/40-turbulence.html)
Christelle July 10, 1998 09:15
turbulence
Hi, I am working with compressible Navier-Stokes equations and I want to compute forced compressible turbulence for Mach number <1..
I would like to have some suggestions or references about the choice of the forcing term. thanks in advance, christelle
Jonas Larsson July 10, 1998 10:18
Re: turbulence
I'm not sure of what you mean with "forced". Could you please clarify that?
Generally speaking you don't have a lot of compressibility effects on the turbulence for Mach numbers below 1. For flows below the hypersonic range (M ~< 3) you can usually neglect things like pressure dilatation, pressure work and pressure diffusion and just use "incompressible" turbulence models, provided you formulate them in a correct conservative formulation.
I'm working with turbulence modeling for supersonic flows (heat transfer in supersonic turbines, max Mach ~ 2), so I share your interest in compressible turbulence modeling.
christelle July 10, 1998 11:14
Re: turbulence
I will clarify the point "forced compressible turbulence"
I want to compute a isotropic turbulence but not decaying in time . So I must add a forcing term in compressible Navier-Stokes equations to make the flow stationary.
I don't want to get by adding this term non physical compressible effects . The flow must stay incompressible (M<1) and I would like to know wich forcing term I could use to have these properties. thanks for responses. christelle
