-   -   Elliptic meshing generation (http://www.cfd-online.com/Forums/main/4074-elliptic-meshing-generation.html)
Meggie November 3, 2001 04:40
please recommend some simple code. I am entry-learner.
Axel Rohde November 6, 2001 00:27
Re: Elliptic meshing generation
I wrote an elliptic mesh generator many years ago, based on four different numerical methods. Unfortunately, I no longer have the report, otherwise I would send it to you (the source code would not help you; I don't even understand it anymore).
Elliptic grid generators are based on Laplace's or Poisson's equation (P = L + source term). In essence, you are solving a (2-D) heat conduction problem, and your converged mesh consists of lines of constant temperature (isotherms) intersected normally by flux lines. There are several ways to solve the Laplace or Poisson equation numerically. In increasing complexity, these are,
SG-SOR
SG-ADI
MG-SOR
MG-ADI
where,
SG = Single-Grid
MG = Multi-Grid
SOR = Successive Over-Relaxation
ADI = Alternating Direction Implicit
You should be able to find references to these methods in the literature. A good starting point for elliptic mesh generation is Chapter 5, "Computational Fluid Dynamics - The Basics with Applications", by John D. Anderson, Jr.
S.P.Asok November 7, 2001 03:08
Mr.Axel,is it that the generated mesh can be used for all kind of discretisations.I am a finite element follower.Regards,asoksp
Axel Rohde November 8, 2001 08:48
Certainly! The elliptically generated mesh has quadrilateral cells. Most FE analysts prefer triangular cells, which can be obtained by simply cutting the quadrilaterals at opposing corner points.
