Non-Isothermal Flows
Old   November 21, 2001, 16:31
Default Non-Isothermal Flows
Juliana
Hi, Could anyone suggest some reference about free surface non-isothermal flows?
Thanks very much,
Juliana.
Old   November 27, 2001, 10:32
Default Re: Non-Isothermal Flows
Patrick Godon
Hi Juliana,
I see nobody answered your posting, so I can try to help, mainly with the non-isothermal part of the question and the physical aspect of all that. I am not quite sure what kind of free surface flow you are dealing with, though I did some work on flows like atmospheres/oceans types, where the free surface of the flow is subject to 'gravity' waves.
Back to non-isothermal, are you interested in other approximation like polytropic, barotropic, or ideal gas equations with energy equations, etc..??
Cheers, Patrick
Old   November 29, 2001, 05:02
Juliana
Hi Patrick,
Thanks for you answer, but I work with incompressible non-isothermal free-surface. Do you know some reference about this problem ?
Cheers,
Juliana.
Old   November 29, 2001, 09:45
Patrick Godon
I have been working in the 'long'wave' approximation using the shallow water equations to model free surface non-isothermal incompressible flow. On a large scale, the ocean and the atmosphere can be modeled as free surface incompressible and they are non-isothermal. In this regime the three dimensional incompressible flow (of the atmosphere for example) can be modeled with a compressible two-dimesional model, since the pressure adds an extra degree of freedom. This extra degree of freedom can be used to model the heigth of the flow for example.
So I am not sure under which conditions you are working, but most probably on a smaller scale, like modeling boats on the water, etc..?
If the shallow water approximation is not for you, then you can try make a seach on the web, on yahoo or whatsover, or maybe someone here has more to say.
Anyhow, check also this web site on free-surface flow:
http://dmawww.epfl.ch/rappaz.mosaic/animations/dam.html
Cheers, Patrick
SIMPLE pressure correction in compressible flows Maarten de Jong Main CFD Forum 7 April 30, 2012 02:23
y+ in high Pr flows vishyaroon Main CFD Forum 0 April 15, 2010 14:24
Free surface flows and multiphase flows Vidar Main CFD Forum 0 September 18, 2008 05:05
calculating recirculating turbulent flows with k-e Abhijeet Vaidya Main CFD Forum 10 November 18, 2002 08:21
Modeling Free Surface Flows Elliot Schwartz Main CFD Forum 5 August 25, 1998 21:03
