Plotting unstructured grids in FAST ??
Old   December 3, 2001, 18:54
Default Plotting unstructured grids in FAST ??
Radhika Gupta
Does anybody knows, in format do we need the data to plot an unstructured grid in FAST. Right now I have the number of nodes, with there x y z coordinates and the number of elements (quadrilaterals) with their connectivity.
any help asap, will be really appreciated.
regards,
-Radhika
Old   December 4, 2001, 07:40
Default Re: Plotting unstructured grids in FAST ??
Pete
I believe FAST (at least the last version I used several years ago) can only handle unstructured grids comprised of triangular/tetrahedral elements. If your quadrilateral grid is I-J ordered you can use the structured PLOT3D format, otherwise you would have to subdivide your elements for the sake of plotting or use another, more flexible package.
Old   December 4, 2001, 08:36
Radhika Gupta
Let's assume that I have triangles aswell of I-J-K order. Now when I try to write in PLOT3D format, the manual specifies some flags for the triangles. I could not understand the significance of the same.
So I give all of them a value of 1 or 2. I do not get the same type of grid I am expecting. Some corners are missing or some last elements seems to be joined with middle elements.
Old   December 4, 2001, 08:52
Pete
Just a guess, but it sounds like with PLOT3D format you may inadvertently be specifying a blanking with the "1" and "2" values you're using, or the I-J ordering isn't quite right. Plotting as a structured grid you shouldn't see any diagonal lines.
FAST also has an unstructured format you can look into, check the manual for:
Grid file:
# nodes, # tri faces, # tetrahedra (x,y,z), i=1,# nodes (triangle connectivities), i=1,# tri faces(tri face boundary conditions), i=1,# tri faces (tetrahedra connectivities), i=1,# tets
The Q file is similar to PLOT3D format, except the Q arrays goes from 1 to # nodes.
That's about all I remember, it's been a while. Good luck!
Old   December 9, 2001, 19:24
Abhijit Tilak
Hi
Consider using GMV. It can plot any damn thing as long as u give correct connectivity information. GMV is available on majority of platforms. I don't remember the web page addess but u can search thru google. hope this helps. Abhijit
[Other] OpenFOAM - structured or unstructured Grids ? thomasduerr OpenFOAM Meshing & Mesh Conversion 22 November 24, 2018 23:18
combining structured and unstructured grids Shane FLUENT 2 January 23, 2007 20:57
BC implementation on unstructured grids sunny Main CFD Forum 1 October 10, 2004 07:27
Fast searching on unstructured grids Tony Main CFD Forum 2 January 7, 2002 08:31
TVD/NVD in unstructured grids m.s. darwish Main CFD Forum 0 August 24, 1999 13:44
