-   -   Kolmogorov scale (http://www.cfd-online.com/Forums/main/4204-kolmogorov-scale.html)
T.Misawa December 11, 2001 08:06
Kolmogorov scale
Hello all
Does any one know how to esitmate Kolmogorov micro scale?
I know Kolmogorov scale can be obtained from viscosity and dissipation rate per unit mass. Should I obtain dissipation rate from DNS or experiment results ? Can I estimate Kolmogorov scale without DNS or experiments?
sylvain December 11, 2001 12:09
Re: Kolmogorov scale
If you know the kinetic energy q/2 and the integral length scale L , you may used the following relationship for the dissipation rate eps :
eps ~ ((q/2)^3/2)/L
Moreover, if you define a tridimensionnal spectrum E(K) by :
E(K) = AK^s for (K<Kmax)
E(K) = c_k eps^2/3 K^(-5/3) (K>=Kmax)
E(K) = 0 (K>Kkol)
where s is the slope of the spectrum for large scale (s=2 to 4).
Then you can find A by continuity in Kmax and eps, L and q/2 from the following relationship :
q/2 = int (E(K)dK)
eps = 2 nu int (K^2E(K)dK)
q/2 L = int(E(K)/KdK) (may be 2*pi somewhere)
this could give you a good idea of the different equalities between all this quantities for turbulence near equilibrium.
sylvain December 12, 2001 05:02
It should have been :
E(K) = AK^s (K<=Kmax)
E(K) = c_k eps^2/3 K^(-5/3) (Kkol>=K>=Kmax)
E(K) = 0 (K>=Kkol)
PS : for K>=Kmax, one can also used the Pao formulation.
