-   -   Speed Limitations of CFD Codes (http://www.cfd-online.com/Forums/main/4222-speed-limitations-cfd-codes.html)
Aldrin Wong December 19, 2001 01:43
The present day CFD codes using say a variety of flux vector or flux difference splitting etc have been amply demonstrated for fluid flows from Mach 0.6 to say Mach 2.0
What about other speeds. Can I use the same codes for same Mach 0.01 ? What about Mach 4 ? What are the issues (CFD wise) involved ?
Would appreciate if anyone can shed some light on this.
Cheers Aldrin
sylvain December 19, 2001 07:08
Re: Speed Limitations of CFD Codes
Limitations are from :
- the validity of the Navier-Stokes equations (ratio mean free path / fluid particules size);
- the numerical scheme you use (ex : FEM for incompressible flows (Mach number <= 0.6); FVM with Roe or ... for compressible flows (converge faster without preconditionning for Mach number greater than 0.3)).
- the turbulence model you use : for Mach number lower than 2 the turbulence is suppose to be nearly incompressibe (Turbulent Mach Number = sqrt(turbulent kinetic energy) / sound speed lower than 0.6). For higher Mach number, the turbulent Mach number rise and the usual turbulence models are no more satisfactory.
I probably forget other aspects, but hope thats help.
Sylvain
Aldrin Wong December 19, 2001 21:40
if i do solve everything using the Euler equations, will that help ?
If I can recall correctly, the farfield should be bigger for very high speed flows (Mach > 2) ??
Whereas convergence is more of an issue at very low speeds.
