-   -   MPI for parallel processing (http://www.cfd-online.com/Forums/main/4266-mpi-parallel-processing.html)
Chuck Leakeas January 7, 2002 23:42
Hello all, I'm wondering what book people have used to learn the Message Passing Interface (MPI) language for parallel processing supercomputers? Thanks!
Junseok Kim January 8, 2002 15:14
Re: MPI for parallel processing
If you are beginner in MPI programming, then before buying any books, you may check below website, and after that, you can buy some books which suits you most.
http://www.llnl.gov/computing/tutori.../mpi/MAIN.html
http://www-jics.cs.utk.edu/PCUE/
Chuck Leakeas January 8, 2002 18:05
Thanks for the response Junseok I'll check those web sites!!
Neale January 14, 2002 20:31
Hi
When I learned MPI back in the day:
Snir, Marc et. al. MPI The Complete Reference. The MIT Press. Cambridge, Massachusetts, 1996. ISBN 0-262-69184-1.
Gropp, William et. al. Using MPI Portable Parallel Programming with the Message Passing Interface. The MIT Press. Cambridge, Massachusetts, 1994. ISBN 0-262-57104-8.
I think that there are newer versions of both these books now.
Dan.
Chuck Leakeas January 14, 2002 21:18
Thanks Dan I will keep your suggestions in mind.
Chuck
