temperature decreasing to zero
Old   January 19, 2002, 02:31
Default temperature decreasing to zero
Nathan Luetke
Hello, this is my first post. I have been using FLUENT for a while and have this problem that has been troubling me quite a bit lately. I am using FLUENT 5.5 and am running a 2-D unsteady transonic/supersonic combustion case. The fuel is simpley H2 and the inlet is from a profile at Mach around 2.5 if that matters any. My problem is that as the time steps increase (the problem even occurs with steasy flow) I have a zone right downstream of the fuel inlets (one top and bottom) which inject at M=1 where the temperature tries to drop to zero, thus resulting in a divergance. The fuel is at 233 K static temp. so I limited the minimum temperature to 100 K and played around with the positivity limit. CFL is 1.0, changing that appears to have no affect. the number of cells with this problem vary from 100 to 3000. I am using implicit method and try time steps from 1e-6 to 1e-5, nothing is working. explicit does not allow the residuals to drop below 1e-1 so I know that does not work. Would multi-grid affect anything? (I am not too familiar with that but if anyone knows if it might work, I will mess around with it.) The grid apears to be fine, no major jumps etc. so I doubt that is the problem. PLEASE!!, If anyone can help or has any input please let me know. Thankyou in advance for any help you all can offer. -Nathan L.
Old   January 19, 2002, 16:18
Default Re: temperature decreasing to zero
Nathan Luetke
This is a continuation of my message, I am using 2nd order explicit, not implict, that does not do anything but diverge. Thanks again for any help that can be offered
Thread Tools
Trackbacks are On
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 10 March 5, 2015 07:57
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Too large temperature decreasing above sound speed Roland R CFX 4 December 7, 2009 18:17
monitoring point of total temperature rogbrito FLUENT 0 June 21, 2009 17:31
Decreasing temperature of combustion Jacek FLUENT 5 February 18, 2002 01:45
