time step
Old   January 30, 2002, 10:32
Default time step
yangqing
in fluent help, it says that the time step can be specified as you will,because it's method is steady. but i read some books, i feel the time step is relation to grid. why? thanks
Old   January 30, 2002, 11:13
Default Re: time step
wang
There is a CFL number that constrain the time step. Generally speaking, the finer the grid is, the smaller the time step should be. Otherwise the solution may diverge. Furthurmore, there would be other constraint on time step concerning flow features. If you use RANS euqations, time step must be much more greater than the turbulent fluctuation time and smaller than the characteristic time of large scale.
Old   January 30, 2002, 22:29
Anup
I do not know about Fluent, but some codes calculate both the convective(cfl number) as well as diffusive (von-neumann number) time step and then use the minimum of the two. So the time step varies with each iteration.
Anup.
Old   January 31, 2002, 04:22
John
If one tries to obtain a steady solution by time marching, then there is no time-accuracy problem and the time step can be taken as big as allowable by solution stability.
If one simulates an unsteady flow, then Courant number is a good reference for choosing time step.
HELP! time step too small? meangreen Main CFD Forum 6 May 31, 2018 10:41
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Hydrostatic Pressure and Gravity miliante OpenFOAM Running, Solving & CFD 132 October 7, 2012 22:50
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
