-   -   do me a favour (http://www.cfd-online.com/Forums/main/4403-do-me-favour.html)
bjcz February 11, 2002 11:31
do me a favour
Hi, Friends,
who know the expression of exact/analytical solution of the following problem? (or in which book and paper i can find the formula?)
this is a acoustic/aeroacoustic problem:
in uniform flow with Mach number of 0.5, a two-dimensional pressure pulse is introduced somewhere in the mean flow, and then the pulse propagates in the mean flow
the pulse is as follows
P = A*Exp{ (-ln(2)/a**2)*[(x-x0)**2 +(y-y0)**2] }
where P represents pressure. A is amplitude of the pulse. a is a constant. (x0,y0) is the position of the introduced pressure pulse.
what is the analytical solution of propagation of the pulse?
this problem's analytical solution must exist.It seems that it is a simple problem because some people compare their computational results with the analytical solution. unfortunately, i don't know that.
looking forward to reply at your earliest convenience.
thanks in advance
Markus Lummer February 12, 2002 02:35
Re: do me a favour
Have a look at:
Tam, C.K.W.; Webb, J.C. : "Dispersion-Relation-Preserving Finite Difference Schemes for Computational Acoustics.", J. Comp. Phy. 107, 262-281 (1993)
Perhaps you will find what you want on pages 280-281.
Hope this helps
Markus
