-   -   code validation (http://www.cfd-online.com/Forums/main/4406-code-validation.html)
Ma February 11, 2002 18:27
code validation
Dear Friends,
I need to validate my 2D Euler code, can anyone tell me what are the most commonly used problems for validation?
Also, how about Navier-Stokes code validation?
Thanks in advance!
Ma
Kunal Jain February 11, 2002 20:20
Re: code validation
Shear the top and the bottom walls..shear the right and the left walls..with gravity switched off.. then shear all the four walls.. u should see a dead zone at the center.
the next check can be pipe flow
Ma February 12, 2002 11:25
Re: code validation
Thanks, Kunal.
Could you provide some reference?
Ma
Kunal Jain February 12, 2002 11:31
Re: code validation
Regarding the reference, i think the book by peric might be useful. also i might have some results which if you want to look at, i'll be happy to email them to you.
Ma February 12, 2002 11:56
Re: code validation
Thanks again for your soon reply.
I'd like very much to look the results you mentioned. Would you please email them to me at mafuhua@psu.edu?
Ma
gita February 12, 2002 18:29
Re: code validation
Hi Ma,
Standard test caess are: (i) 2D incompressible,Euler flows: Flow over a NACA 0012 airfoil,circular arc bump
(ii) 2D,incompressible NS flows: Lid-driven Cavity,Flow over a circular cylinder,flow over a flat plate(all for laminar cases). (iii) 2D compressible NS: shock-wave boundary layer
It depends on the problem that you are solving(steady/unsteady). There are enormous literature and you need to go to the library and do some "search" and by doing so you gain a lot in the process. Hope your question is answered. If not you can tell about your problem. Some test cases are easier than others.
gita
Ma February 12, 2002 19:32
Re: code validation
Hello Gita,
I am currently developing a 2D Euler code to study the plume dynamics: a detonation wave ( or a strong shock) traveling out from a combustor connecting with a CD nozzle. I've got some nice results from which the vortex, bow shock, reflected oblique shocks can be clearly oberved. I also read my code carefully more than one times. However, I've not yet run any validation case.
In the near future, I will update my code to a NS solver.
So I'd like to learn and know some commen sense and basic knowledge about code validation.
By the way, I found this forum here is a good place to learn CFD because of its fast-active-communication.
Thanks.
Ma
gita February 13, 2002 11:30
Re: code validation
Hi Ma,
Glad to hear that you are getting good results. I have run the case for NACA 0012 airfoil for subsonic,transonic and supersonic cases using structured grids(using upwind schemes like flux-difference and flux-vector splitting schemes). I have tested out double blast wave(a very strong shock and there are multiple collisons going on)for 1D case. In future if you want to cross check I can help you. For a 2D NS,you can test lid driven cavity. It's fairly easy esp in stream fn-vorticity formulation. Yes this forum is good. There are good number of people who have got very good hands on experience with many CFD problems. Hope people benefit from this. And it's a good place to refresh one's knowledge of CFD also. Good luck in your research.
gita
Praveen Chandrashekar February 14, 2002 11:25
Re: code validation
You might look at the following sites
http://www.grc.nasa.gov/www/wind/valid/archive.html
http://www.caselab.okstate.edu/research/validation.html
